Dynamic Compression Question
#241019
03/02/09 03:51 PM
03/02/09 03:51 PM
Posts: 290 Regina, Sk. Canada
Super6
super street
super street
Regina, Sk. Canada
I'm thinking about a sbd motor and I wanted to know what a good target dynamic ratio would be to shoot for when running 91 octane?
Second question, how much will this number have to be raised when running aluminum heads?
I'm shooting for around 7.8 dcr at 1893ft. elevation on an iron headed smallblock.
thx
Bench racer extroirdinaire!
Re: Dynamic Compression Question
[Re: DaytonaTurbo]
#241021
03/02/09 04:01 PM
03/02/09 04:01 PM
Super6
super street
super street
Regina, Sk. Canada
Poking around I've heard mid 7s for open chamber/large bore engines, high sevens for closed chamber heads, maybe a little more with heat control and lowish 8s with aluminum heads and fuel injection. I was hoping to pin it down more than that.
[Re: Super6]
#241022
03/02/09 05:26 PM
03/02/09 05:26 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You need to know the whole combo. What pistons, what heads, and what cam? Very generally, under 8:1 will feel soft down low. 8-8.25:1 is about max for open chamber iron heads. 8.25-8.7:1 is about max for closed chamber aluminums.
[Re: moper]
#241023
03/02/09 05:41 PM
03/02/09 05:41 PM
Super6
super street
super street
Regina, Sk. Canada
I was looking at the new iron ram heads with the small combustion chamber. Flattop pistons and either comp's XS268S solid 230/236 or XS276S 236/242 at 0.50". Then again I do not know if the extreme energy line up builds more pressure than usual so that again may through the numbers out.
Does anyone run over 160 psi cranking pressure in a small block and have no gasket issues or ping issues on 91 octane?
[Re: Super6]
#241024
03/02/09 09:55 PM
03/02/09 09:55 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I run 165 PSI in my 318 with tight quench and high swirl iron heads (302s), it runs fine on 89 in the summer heat and 87 in the winter and I run a 195 t-stat. More preasure and more octane would be a good thing. I am thinking about going from 9.5 static comp to 10.00 by swapping head gaskets from .039 felpros to .028 mopars that also have a smaller bore. My pistons are .005 below deck. My cam is a factory 273 2bbl cam. Also a thermo-quad carb to help keep the fuel cool. Heat crossover is blocked. My dads geo metro when new had 220lbs cranking compression when new and never pings on 87
[Re: Super6]
#241026
03/02/09 11:10 PM
03/02/09 11:10 PM
moper
Columbia, CT
I've run as high as 185 on open chamber iron heads (on a 383) and there were no issues with ping or detonation. But the tune was spot on. I dont think you'll want to run a flat top. I'd be looking into a dished piston. You want a small tight chamber, and a tight quench, and you can get away with more. The 230°@.050 cam might be a little small. What size smallblock?
[Re: moper]
#241027
03/03/09 12:56 AM
03/03/09 12:56 AM
Super6
super street
super street
Regina, Sk. Canada
The block will be a 360. I was looking at the diamond piston set in at 0 deck. 9.9 cc dish. .040" gasket.
I'm new to the engine building thing so I am trying to err on the cautious side.
[Re: Super6]
#241028
03/03/09 01:15 PM
03/03/09 01:15 PM
moper
Columbia, CT
P/N 51405 - 21cc dish, 1.457 compression height. With a 62cc chamber is 10.25:1 or so static, and with the 4" crank, you need a cam that will be closing the intake valve by 47°@.050" after Bottom Dead Center on the compresssion stroke. That will give you abour 8.3:1 dynamic, with a .040" quench distance. That's pump 89 range.
