Radiator shroud repair, what works? Glue? Custom mix or ? #2408277
11/24/17 03:31 PM
11/24/17 03:31 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I have a near perfect 1970 26" radiator shroud with one damaged mounting point & a larger, perfect broken donor part for the same section.
What type of glue / bonding agent have you used that works with this type of plastic?
Thanks! beer
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408343
11/24/17 06:03 PM
11/24/17 06:03 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The same type of plastic ground into small chunks and mixed with acetone to make a paste with. A Scott Harms trick from way back.
Also glued a tab on plastic grill back together before knowing of the above method with pvc cement. Seems pretty strong.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408360
11/24/17 06:50 PM
11/24/17 06:50 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I knew that about grilles, are the shrouds the same type of plastic?
Thanks.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408369
11/24/17 07:39 PM
11/24/17 07:39 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I want to say they are same material.
I'd ask Scott as he would know for sure.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408373
11/24/17 07:48 PM
11/24/17 07:48 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
You know Scott, he will see this thread sooner or later...... ;-)
Thanks again.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408400
11/24/17 08:56 PM
11/24/17 08:56 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It's made of a Polyethylene blend (grills are ABS, an entirely different material with different properties). Problem is that the Polyethylene/Polypropylene family of plastics are very "slick" and HIGHLY chemical resistant (they make containers for acids, paint stripper, etc. from a similar material due this fact). So, it's rather like gluing a broken candle together, glues, fiberglass and such don't adhere to it well, they just sit on top and eventually peel off. Therefore, pretty much impossible to "glue it" with anything. When they make repairs to large industrial containers they use heat and weld it together but this leaves visual melted plastic scaring which don't look good on our car parts. If you have light scratches or cosmetic imperfections you can use plastic epoxies as a filler and finish paint the shroud black with SEMS interior paint and get a nice finish, but as you know, O.E. correct is bare plastic.
.02
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408415
11/24/17 09:36 PM
11/24/17 09:36 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Thanks for the info Scott.
I heard from a pal that has used this for shrouds with good results - https://www.amazon.com/3M-08115-Panel-Bonding-Adhesive/dp/B000PEW4MI
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408425
11/24/17 10:34 PM
11/24/17 10:34 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Here is a photo of the torn hole in the shroud & the donor part.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408464
11/24/17 11:51 PM
11/24/17 11:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I've never tried panel bonding adhesive but it might be aggressive enough to work. One thing though, that stuff is expensive, weigh the costs of that vs a better shroud .02
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408577
11/25/17 08:49 AM
11/25/17 08:49 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I used J-B Weld in the past with great results. After everything cured, I used SEM Trim Black to hide the repair.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2408582
11/25/17 09:41 AM
11/25/17 09:41 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Could you use one of the JB Weld putty style epoxy sticks? I know they make them in several varieties. Pick up a stick and mix it up on something and test it out, then paint to match maybe? Early morning, so not sure if the brain is working at 100% yet with this idea.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: MI_Custumz] #2409102
11/26/17 01:57 PM
11/26/17 01:57 PM
georgia
moparpro Offline
moparpro  Offline
georgia
i used the clear jb weld and painted it over with sem paint came out nice and very sturdy.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2409251
11/26/17 07:58 PM
11/26/17 07:58 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
stop by a body shop that has a polyvance plastic welder.
if they have any skills that's a 5 min repair after the welder warms up. if they use the black fiberflex rods, https://www.polyvance.com/FiberFlex-1/, it will be the same color as the shroud. a little detail sanding it will be as good as new.
plastic welding demo, https://www.youtube.com/watch?v=cMT_DHYbsYE
perception is 90% of reality
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2409359
11/26/17 11:11 PM
11/26/17 11:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Mr T2U shows the proper way to bond PP materials. The cosmetic detailing to hide the weld will be the trickiest part.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2409385
11/26/17 11:58 PM
11/26/17 11:58 PM
MO
cdp Offline
cdp  Offline
MO
superglue and baking soda. Simple, cheap.
https://www.youtube.com/watch?v=A-XEG57RX4Y
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: ScottSmith_Harms] #2409515
11/27/17 10:46 AM
11/27/17 10:46 AM
Mr T2U Offline
Mr T2U  Offline
if the person doing the repair knows what he is doing it's a 30min undetectable repair.
both ridges are still present on the shroud so the repair is easy. i do bumper repairs like this a LOT at work. if you use the welding rod i have listed the weld will be the same color as the shroud.
just take a SMOOTH piece of metal, the foil tape wrinkles when you use it as a backer filling holes and embeds itself in the weld.
put the metal on the front side and attach securely.
fill the hole with rod from the back side and smooth the weld with the iron.
after the weld is cool pull the metal from the weld.
the surface should be smooth. just a little detail sanding and quick paint blend and you are done.
the sanding will be the same as filling it with adhesive.
the biggest problem will be the repair area will look to good compared to the rest of the shroud.
Re: Radiator shroud repair, what works? Glue? Custom mix or ? [Re: Alaskan_TA] #2409542
11/27/17 12:27 PM
11/27/17 12:27 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Plastic welding is the way to go.
But I just repaired one using 3M panel bond, shroud was broken clean through. Needed to V-groove both sides but it’s a very strong repair.
In either case the shroud will have to be painted.
