Re: A518 floor pan mods - 69 charger ??
[Re: IMGTX]
#2409850
11/27/17 10:57 PM
11/27/17 10:57 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
On the mod you did.
Did you trim anything on the transmission or just thin out the Torsion bar crossmember?
Same as above pictures of CNXT
[Re: BDW]
#2411255
11/30/17 01:29 PM
11/30/17 01:29 PM
Posts: 19,355 north of coder
moparx
I picked up a used Kwik Lift for $400 when I did the swap, would have been a pain without it. funny you should mention that. several years ago, i drew up and fabbed a lift similar to the "quick lift", but used truck air bags to raise and lower it, putting the tire bottom 20" in the air. i have all the parts made, but life dealt me a tough hand, and it's only about half put together. initial testing proved it will work as designed, but it's just one of many projects i need to finish. the bags are supposed to support 7000lb at 10psi. there are safety stands to support the rear of the ramps in use, while the front tires are supported on "piers" at the front.
[Re: roadrunninMark]
#2411425
11/30/17 07:32 PM
11/30/17 07:32 PM
CSK
Pattison Texas
CSK, is that an aluminum driveshaft? Did you get it out of a RT Dakota or aftermarket? had it made
