89 Dakota 3.9 Fuel Lines #2408626
11/25/17 12:56 PM
11/25/17 12:56 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
The small rubber hoses that run in front of the engine and connect the metal to metal fuel lines. Noticed dry rot and want to replace them. Are these lines under pressure, and if so, best way to relieve it?
Grandma always said I had "hands of gold"!
Re: 89 Dakota 3.9 Fuel Lines [Re: CHRGR69] #2408865
11/25/17 11:04 PM
11/25/17 11:04 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
If it is the one I think yes under pressure, but no big deal just rap a rag around it and undue. Cold engine preferred.
Re: 89 Dakota 3.9 Fuel Lines [Re: CHRGR69] #2409423
11/27/17 12:51 AM
11/27/17 12:51 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Both fuel lines are under pressure, and remain so, the pressure does not drop off on its own (unless something is wrong). Once the pressure is released, and the fuel is emptied from the line, no more fuel will be present until you turn on the key. Both lines will have fuel until it is drained, they each hold about a 1/2 lid full of fuel from a spray paint can. An EFI system is under pretty high pressure. If you cut the line, it will spray out hard and fast then be done. You may be able to catch the gas with a drain pan, but wrap a rag around the cut point so it won't spray in your face. Gene
Re: 89 Dakota 3.9 Fuel Lines [Re: CHRGR69] #2409459
11/27/17 01:51 AM
11/27/17 01:51 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Isn't there a shrader valve on the line some where to relieve the pressure slowly?
Re: 89 Dakota 3.9 Fuel Lines [Re: CHRGR69] #2409818
11/27/17 09:57 PM
11/27/17 09:57 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
89 truck TBI, full pressure runs about 15 psi.
Re: 89 Dakota 3.9 Fuel Lines [Re: 135sohc] #2418081
12/13/17 06:18 PM
12/13/17 06:18 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
No biggie. Loosened clamps, slit and twisted hoses, and very little fuel came out. All better now. Thanks all.
