Re: 73 charger SB swap for BB
[Re: scottgregory1973]
#2405268
11/18/17 01:25 AM
11/18/17 01:25 AM
RapidRobert
Welcome here. You would need a BB bellhousing & I'm sure the related BB clutch parts (flywheel/disc/hat/fork etc) . BB pump housings are available to match your current radiator lower nipple side position IF it has enough capacity (I'd want a 3 row) & is in good enough shape (not partially clogged). Wiring can be extended easily (always keep the same color including color with tracer as OE). Headers make the most power but have issues, not sure what brand to recommend. iirc the K member is the same you just use BB mtr mts (others will clareify).
#2405293
11/18/17 02:12 AM
11/18/17 02:12 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Welcome to the board fellow Hoosier. š
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
#2405356
11/18/17 09:57 AM
11/18/17 09:57 AM
Posts: 5,824 ohio
ruderunner
ohio
Unfortunately 73 up b bodies do have different k frame for big and small block engines. But I think Schumacher makes conversion mounts.
What year engine? What small block currently? There may be balance problems without the correct flywheel.
You'll need new head pipes wether you use headers or manifolds.
I'd run the existing radiator, if it turns out inadequate it's easy to change later.
Power steering brackets may need to change
Angry white pureblood male
#2413940
12/06/17 12:01 AM
12/06/17 12:01 AM
340clone
I just checked, have the huge cutout with mat cover. That right there is half the battle! I restored a 318 '74 Charger twelve years ago and sold it to a guy that put a 440 in it. I recently bought it back from him and I'm doing a few things to it to give it a more original appearance. He DID change the crossmember for BB application, but didn't do anything with the passenger side fender. I now have to remove the motor to properly cut out the inner fender and add that large mat. I'm so not looking forward to that...
#2414122
12/06/17 12:26 PM
12/06/17 12:26 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
thanks everyone. someone told me my VIN numbers says it's a factory 400 4spd car. I bought a 68 440 with 915 heads? so i'm a body guy not mechanic. I did rebuild the clutch two winters ago. the story is the guy I bought car off of put a small block in to give his dad a last ride before he passed away. when I changed the clutch I had to pull a torsion bar to make room. looks like the motor was to close to firewall or i'm just special. in the trunk it had motor mounts and another bell housing. Your VIN will confirm that it's a 400, but it won't tell you the trans. You'll need a fender tag or broadcast sheet for that.
[Re: 318 Stroker]
#2417644
12/12/17 10:57 PM
12/12/17 10:57 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Other than Schumacher as mentioned, Brewers Performance is your Mopar source for 4 speed parts and knowledge. They've been doing this a long, long time.
Iām listening.
