Re: 6.1 Intake vs Edelbrock Clone: Any Real Data?
[Re: moparmitch]
#2404808
11/17/17 02:42 AM
11/17/17 02:42 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Somewhere i have 6.1 intake flow numbers while bolted to a thitek head. A ported stock intake flows extremely well and probably hard to beat.
What Edelbrock should have done was make the intake with 7-8" runners instead of making the same basic intake as a stock 6.1.
But if you have or want to go buy a new stock 6.1 intake than the edelbrock is cheaper
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: moparmitch]
#2404856
11/17/17 08:54 AM
11/17/17 08:54 AM
Posts: 153 MI, USA
moparmitch
MI, USA
A new edelbrock is cheaper than a used 6.1?
Wow, summit lists the e-brock at $800, which seems crazy...
So, in ported form the e-brock will at least be the same or better than a ported 6.1?
How does the stock 6.4 intake compare to these manifolds if we had it locked open for upper rpm performance?
[Re: moparmitch]
#2404892
11/17/17 11:32 AM
11/17/17 11:32 AM
sixpackgut
Charleston
They use either the 5.7 or 6.4 plastic intake in the trans am cars so Im willing to bet the work good too but I really dont know.
A new stock 6.1 intake has gone way up in price
[Re: moparmitch]
#2405047
11/17/17 04:22 PM
11/17/17 04:22 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I did some reading on guys who have compared the 6.1 and 6.4 intake and the 6.4 made more HP than a stock 6.1 pretty much all the time and was real close to a ported 6.1, everyone was belly aching they couldn't port the 6.4 because its plastic. I would bet that with compression maximized for the plastic ones superior heat insulating properties the 6.4 would make more HP than even a ported 6.1 but if compression is not optimized and just straight up swap the ported 6.1 still wins. It also seems the 5.7 eagle truck intake was righ there in the mix and maybe even a hair better than the 6.4 but because of the hood clearance issue was not practical for a lot of cars. There is a lot of info on the internet machine if you can wade through the guys thinking a hellcat hood turns their R/T into a hellcat.
[Re: moparmitch]
#2405191
11/17/17 09:45 PM
11/17/17 09:45 PM
Posts: 153 MI, USA
moparmitch
MI, USA
Good stuff guys...
This is helping to confirm my decision to get a used 6.4 or 5.7 vvt motor (preferably 6.4) for my project. If I can figure out how to post pictures on here, maybe I'll sport some pictures to look at and get something new going on the G3 forum. Things seem to be a little slow here - lol
So, for newer oem intakes, they seem to be pretty good performers.
Is the 5.7 truck intake taller than a 6.4 challenger intake?
Is a jeep intake different from a truck intake?
I haven't decided yet, but here's what I'm considering right now:
1) 6.4 motor to run as is with the mopar crate engine kit electronics
2) 6.4 with locked cam phaser, dragpack style intake and carb, MSD or FAST ignition
The car is light right now (1560 lbs without motor,trans,fuel system, wiring). I'm hoping it's around 2500ish lbs when its completed, we'll see...
[Re: moparmitch]
#2405286
11/18/17 01:56 AM
11/18/17 01:56 AM
Posts: 4,255 Canada
WO23Coronet
Canada
5.7 truck is taller than 6.4 car intake. Jeeps use car intakes. Either iteration of your 6.4 would make a 2500 lb car flat out dangle
[Re: moparmitch]
#2406658
11/21/17 03:48 AM
11/21/17 03:48 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Well
I have not had a edelbrock intake in my hands yet But I know that more than a few have
I see about 1k to get that intake That's the purchase of it Along with there required fuel rails
For a lot less money you could port the stock 6.1 intake and be ahead of it
If your starting from scratch then I guess you might be able to justify The edelbrocks purchase
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: moparmitch]
#2406711
11/21/17 10:45 AM
11/21/17 10:45 AM
gremlinsteve
houston texas
I'm currently working on a sheet aluminum intake idea Which will be a shorter runner in say the 5-6 inch area
We hope that the intake is no taller than a standard 6.1 style Intake so there won't be fitment issues
The first design will be boasting an internal intercooler for Cintrifical blower cars that have no or little room for a standard intercooler
[Re: moparmitch]
#2407083
11/21/17 10:42 PM
11/21/17 10:42 PM
Posts: 10 Mid West US
GoForBroke
Mid West US
I spoke with the guy who designed the new head and he basically told me it's designed to be modified. Ported and played with hence the reason they added material around the runners so we could make em how we liked them is what he stated. Ribs on top of the combustion chamber, extra thick deck, and mainly designed with boosted guys in mind.
As for the intake he stated the same. It needs porting and they left the whole plenum bottom removable for easy access. They also added the bosses for direct port nitrous. The injectors actually point at a right angle to airflow which is why I believe they make you use their rails. A mistake in my opinion but I think it has potential.
The issue I see with the 6.4 intake is there are fuel trim offsets for certain cylinders in the factory tunes on the vehicles that use them. That tells me airflow distribution must be off on one side.
You can also make a simple setup with a MSD window switch and activate the built in SRV (short runner valve) and make some decent gains up top while keeping things torquey down low with the 6.4 intake.
[Re: moparmitch]
#2407401
11/22/17 03:52 PM
11/22/17 03:52 PM
HotRodDave
Kalispell Mt.
Some of it may be exhaust related also... just throwing that out there.
