Re: older crate engine MP 505
[Re: sogtx]
#2402844
11/13/17 12:48 AM
11/13/17 12:48 AM
Posts: 4,457 Washington
madscientist
Washington
Just resleeve it. Why not?
[Re: sogtx]
#2402879
11/13/17 02:13 AM
11/13/17 02:13 AM
fast68plymouth
So. Burlington, Vt.
Whats the problem with running it at .070?
I'd probably(definitely) deck it though.
[Re: fast68plymouth]
#2402914
11/13/17 08:58 AM
11/13/17 08:58 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
I'd probably(definitely) deck it though. No prob Just checking out piston install b4 decking it . Just wondering if Any one else had 8 sleeves in theirs
[Re: sogtx]
#2403037
11/13/17 02:56 PM
11/13/17 02:56 PM
Posts: 43,289 Bend,OR USA
Cab_Burge
Lots of SB NHRA stocker have 8 sleeves Straighten up the bores and have a block that will make some power and live
[Re: sogtx]
#2403058
11/13/17 03:44 PM
11/13/17 03:44 PM
Posts: 1,505 TN
SCATPACK 1
TN
I seem to recall they had a lot of core shift in those early castings. Probably the reason for 8 sleeves. I have also asked about sleeving all 8 holes and was told it was not an issue.
Old Geezer Racing
[Re: sogtx]
#2403109
11/13/17 04:57 PM
11/13/17 04:57 PM
madscientist
Washington
Just resleeve it. Why not? Why resleeve ? Because it's cheaper than a new block and you can buy sleeves now that are very, very good. You can get the old sleeves out, maybe use a slightly bigger OD sleeve and you can get the bore size back to where you want it.
[Re: sogtx]
#2403161
11/13/17 07:01 PM
11/13/17 07:01 PM
sogtx
upstate western ny
I'd probably(definitely) deck it though. No prob Just checking out piston install b4 decking it . Just wondering if Any one else had 8 sleeves in theirs What I meant by THEIrs was their crate engines
