moved my oil filter
#240251
03/01/09 07:17 PM
03/01/09 07:17 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
housing to the front of the motor plate this should cure my drain back issue also puts it inside the frame rail as rule book states it must be only problem is it took the spot I had picked out for my alternator oh well.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: moved my oil filter
[Re: Thumperdart]
#240254
03/01/09 10:26 PM
03/01/09 10:26 PM
dusturbd340W5
Kissimmee Fl.
Thanks guys I am trying to get all these little things finished so I can get it fired off even went and picked up a drum of fuel on Saturday so I am more than ready.Have to get another piece of line tomorrow so I can finish the filter.
