Re: 1970 300 Conv theft prevention
[Re: Andrewh]
#2402121
11/11/17 08:35 PM
11/11/17 08:35 PM
Posts: 1,322 Michigan
crlush
there are a few choices depending on your budget and plans. lo-jack for recovery hidden kill switches so it cannot be started add a stick shift to it so they cannot drive it. Definitely the stickshift.
[Re: polaraholic]
#2402160
11/11/17 09:41 PM
11/11/17 09:41 PM
Posts: 5,345 Planet Earth
RoadRunnerLuva
Planet Earth
Keep a pitbull in the cabin at all times.... Seriously though, install a hidden kill switch, it'll be fine.
Plymouth Makes It!
[Re: RoadRunnerLuva]
#2402233
11/11/17 11:05 PM
11/11/17 11:05 PM
RapidRobert
Lojack or GPS would be good but high dollar I would imagine (never priced one). I think a skilled high end auto thief would be able to bypass/defeat alot of simple alarms. My thought would be to add a common 1/4 turn ball plumbing shutoff valve in the fuel line, with the valve/handle under the seat but hidden somewhat & shut it off then assuming they bypass any alarm then several blocks away it will die in the middle of the street & no amount of cranking will get it going & they will likely panic & have to vacate. it might take several feet of added line to let them get out on a more public road & possibly a vent so all the gas in the line can be pulled forward by the fuel pump (I ain't sure on that as this is just a planned in my head addition), first I have to build something worth stealing! but JC whitless in Chicago used to offer a kit with a button you add on the steering wheel so if you were carjacked you could unobtrusively press the button as you exited the vehicle at gunpoint & it would electrically trip this shutoff valve to make it stall a few minutes later.
[Re: antonellomopar]
#2402464
11/12/17 01:31 PM
11/12/17 01:31 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
We had a few cars at the shop that had hidden kill switches.Even jumping the wires they would not start.Most had a pressure switch that was totally unseen that you had to touch to start.Had a few that had a chip type also.Oh by the way one was a 70 300 vert.I worked on it all the time.Rocky
Chrysler Firepower
[Re: Osyman]
#2402465
11/12/17 01:33 PM
11/12/17 01:33 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Use common sense in parking it. Hidden switches and fuel cut offs wont deter a skilled thief. A big dog might. That said... Don't spoil your trip by worrying about something very likely to NOT happen. Insurance is a MUST HAVE anyway. Pay for parking in secure lots when you need to leave it out of sight for a long time. Enjoy your self. Oh and Welcome to America.
I have mechanical Aptitude. I can screw up anything.
#2402890
11/13/17 03:19 AM
11/13/17 03:19 AM
Posts: 10,226 Someplace you aren't
SomeCarGuy
I pull the rotor so they won’t just pop in a coil wire. I’ve been known to disable a tow rig and park the trailer against a poll to detur theft at a hotel.
I want my fair share
