A customer bought a reproduction hood a couple of years ago for a spare time project I was doing for him. It had a couple of small dings in it but actually looked pretty good in e-coat. It wasn't until I was ready to install it that I noticed it wasn't as nice as it first appeared. When I repaired the obvious spots and started blocking it I found it wasn't nearly as stright as I had thought. I also had a hard time getting it to close right. That's when I noticed that it was twisted. When it was open one side of the front was noticably higher than the other. When I corrected this it shut perfectly.
Now to the actual question. The outer sheetmetal is a little low at the 4 corners of the shaker opening. The trim ring lays in the hole perfectly, no high or low spots in the edge it attaches to. It has a nice fit with the edge of the hood, no high or low spots there. My problem is that my customer thinks I should have 'fixed' the areas at the corners next to the trim ring opening. He says the metal should be perfectly straight all around the opening. I really don't see how that would be possible with this hood. If the edge was higher in the corners, the trim ring would be 'sunken' below the edge on the corners. If the area where the trim ring fits was higher in the corners (to make the skin higher and more level or stright), then the area where the trim ring sits wouldn't be level.
I hope this make sense. What I need to know- are other hoods the same, either original or repros?
I'm attaching a pic which I hope illustrates the problem. All 4 corners by the shaker opening are low like you see in this pic. Yes, I know the hood should have been sent back but he had bought it quite awhile back and I didn't realize it had so many problems until I started working on it.
TIA,
Dallas
