Pitman Arm #2398416
11/04/17 03:44 PM
11/04/17 03:44 PM
A shed in England
Tig Online work OP
Tig  Online Work OP
A shed in England
Hi All.
I recently bought a new pitman arm for my '74 Challenger, unfortunately it doesn't fit. The splined shaft diameter is larger than the one on the steering box so it's way loose. I converted my car to manual steering many years ago. Not sure if the manual steering pitman arms have a smaller spline or I have an earlier model ('70 '71) steering box on the car.
Anyone know whats the deal?
TIA up
Re: Pitman Arm [Re: Tig] #2398434
11/04/17 04:55 PM
11/04/17 04:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Early manual boxes used a smaller diameter output shaft than the power boxes.
Don't be the exception.
Re: Pitman Arm [Re: Tig] #2398437
11/04/17 05:10 PM
11/04/17 05:10 PM
n.c.
geo. Offline
geo.  Offline
n.c.
All E bodies with manual steering came with the smaller spline size, they sent you the wrong part. The larger size was OEM on '73-4 cars with power steering.
Re: Pitman Arm [Re: Tig] #2398440
11/04/17 05:13 PM
11/04/17 05:13 PM
A shed in England
Tig Online work OP
Tig  Online Work OP
A shed in England
Thanks Guys for clearing that up. Order was my bad, I just assumed it was a '74 steering box.
