Re: Reverse Cowl or not [Re: an8sec70cuda] #2396528
11/01/17 10:10 AM
11/01/17 10:10 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted By an8sec70cuda
Guess you know how I stand on this. smoke
LOVE IT !!!!!! smile
Re: Reverse Cowl or not [Re: JH23] #2396619
11/01/17 01:04 PM
11/01/17 01:04 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Originally Posted By JH23
If it works, run it. It's all about speed isn't it?
iagree
72 Plymouth Roadrunner 11.08@123.25
Re: Reverse Cowl or not [Re: ozymaxwedge] #2396636
11/01/17 01:28 PM
11/01/17 01:28 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I have a cowl on my 71 only because a 6 pack scoop looks terrible on a 3rd gen Charger because it has to sit so far back on the hood.
At first I hated it, but now that it has been on the car awhile it has grown on me.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Reverse Cowl or not [Re: ozymaxwedge] #2397182
11/02/17 07:38 AM
11/02/17 07:38 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
having witnessed the improvements first hand with the Dart, adding a cowl over a 6 pak has been a no brainer for my new project. At 150mph+, areodynamics come into play & i dont want a forward facing parachute slowing me down. My preference is to have it real close to the screen, just like that look.
Re: Reverse Cowl or not [Re: ozymaxwedge] #2397328
11/02/17 02:48 PM
11/02/17 02:48 PM
an8sec70cuda Offline
FWIW...when my car ran mid 10s, the cowl hood ran just as good as the 6 pack hood.
What makes it better...the cowl hood wasn't sealed to the carb, but the 6 pack hood was. The seal I had on the 6 pack hood worked too...was a tenth quicker and 1 mph faster sealed up.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Reverse Cowl or not [Re: an8sec70cuda] #2397552
11/02/17 10:49 PM
11/02/17 10:49 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
That cowl hood is worth about 2mph @ 150 versus a forward facing scoop. If my car didn't have one on it for twenty yrs I would change mine to a cowl.
Re: Reverse Cowl or not [Re: OUTLAWSSAA] #2397710
11/03/17 08:26 AM
11/03/17 08:26 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Ideally I prefer no scoop but even with this 3.5" cowl, it was the only way to make the "hardware" fit properly.
The key to a cowl hoods aesthetics I believe is to make it "flow" with the car with a tapered look, not have it come rearwards from the front with a sudden "Jimmy Durante'd" hike in its rearward height.
This is especially important on a shorter wheelbase car where a taller cowl scoop take away from the lines of the car and make it look "stumpier" when viewed from the side.
Mine will be sealed in due course.
Re: Reverse Cowl or not [Re: ozymaxwedge] #2398498
11/04/17 07:27 PM
11/04/17 07:27 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Re: Reverse Cowl or not [Re: LAD 524] #2398585
11/04/17 11:02 PM
11/04/17 11:02 PM
Australia
O
ozymaxwedge Offline OP
O
Australia
Your car is stunning mate, unfortunately to achieve what I thinking I will have to go 6" cowl, the 2 carbs on top of the Indy tunnel are at about 4" out at the front.
I have ordered a 6",still not sure but as it sits I have this fibre glass hood sitting here unusable so I will sit it on there and stand back for a look.
Will it stand out more than with carbs and air cleaners ?? Will it be more of a cop bait ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: Reverse Cowl or not [Re: one bad fish] #2398587
11/04/17 11:03 PM
11/04/17 11:03 PM
Australia
O
O
Australia
Originally Posted By one bad fish
Nice but in your face bad. Im trying to hide things a little shock
1971 Barracuda
Re: Reverse Cowl or not [Re: ozymaxwedge] #2398595
11/04/17 11:29 PM
11/04/17 11:29 PM
bronx n.y
O
O
bronx n.y
lol ok
Re: Reverse Cowl or not [Re: one bad fish] #2399114
11/05/17 11:28 PM
11/05/17 11:28 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
I had been thinking about a cowl hood on my 1970 GTX for some time. I heard all about using a Chevy hood on my Mopar from some of my friends.
I found a fiberglass hood nearby on Craigslist and bought an 8 inch tall Harwood cowl scoop. I joined the two and took it to a test and tune.
That particular night we had a pretty good head wind. In my engineering mind I thought the cowl hood would help the air up and over the GTX and out toward the sides as it gets wider toward the back. I did back to back runs with my forward facing scoop hood and the cowl hood. The result was a BIG disappointment as the GTX slowed down a 10th!
I would be open to ideas to make it work and if not find someone who would be interested in the cowl scoop.
MJ
Re: Reverse Cowl or not [Re: moparjohn] #2399260
11/06/17 11:15 AM
11/06/17 11:15 AM
The rear of the cowl scoop needs to be real close to the windshield for it to work and actually pull air in. I can't slide my hand b/t the scoop and windshield...palm on the glass.
CHIP
