i have a sure grip unit #2395285
10/30/17 12:07 PM
10/30/17 12:07 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
from a 742 case,what would be necessary for me to do in order to install in a 489 case,what parts would be needed.the case is all i have and it has bearings on it.thanks
Re: i have a sure grip unit [Re: moparpro] #2395300
10/30/17 12:39 PM
10/30/17 12:39 PM
is the 742 sure grip pig complete? You are wanting to swap the SG innards to the 489 case cuz it (489 open) has a ratio that you are wanting?
Re: i have a sure grip unit [Re: moparpro] #2395359
10/30/17 01:51 PM
10/30/17 01:51 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
SG from a 742 case should be a clutch type. All that is required is the appropriately sized bearings for the case you are using.
Re: i have a sure grip unit [Re: moparpro] #2395422
10/30/17 03:20 PM
10/30/17 03:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just remember that the gears dont interchange.That and if its a clutch type think about rebuilding it while its out.Just because its a 42 case dosent mean it hasnt had a cone type installed.I have a clutch type from a 66 with 40K that will go into the 89 SG I run now if and when it goes bad.Rocky
Chrysler Firepower
Re: i have a sure grip unit [Re: therocks] #2395426
10/30/17 03:28 PM
10/30/17 03:28 PM
dogdays Offline
dogdays  Offline
You need bearings for a 489 case and a ring and pinion set for a 489 case. You'll need to set up the gears.
Left hand threads on the ring gear!
The 489 case was built with a crush sleeve which is the acknowledged weak spot. You'll need a spacer to replace the crush sleeve, and shims to set pinion fore-and-aft. It is more difficult to set up using the solid spacer, but the crush sleeve does not appreciate jackrabbit starts.
www.doctordiff.com has all the parts you need.
R.
Re: i have a sure grip unit [Re: dogdays] #2395512
10/30/17 05:35 PM
10/30/17 05:35 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
thanks to all.
Re: i have a sure grip unit [Re: 469runner] #2395567
10/30/17 07:05 PM
10/30/17 07:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He will need the sure grip carrier bearings for a 68 and down 742 rear , the hole in the 489 case for the bearing is the same size as the hole in the 742 and 741 case . The bearings for a cone type are different .
Call dr. diff , tell him what you have otherwise you have to order a bearing kit for a 489 and a bearing kit for a 742 to get all the required bearings ... and as suggested set it up wit ha solid spacer.
