Any recent experiences between the 2?
In comparing the 2 I see these advantages...
The FBO rev limiter is adjustable in 200 rpm increments and removes the ballast resistor.
The FBO is a bit cheaper.
The Rev A Nator claims a power increase.
It also has a separate ground strap, which makes sense.
Laura at R/T garage is hot.
Has anyone compared the side by side or had any issues?
Wanting to use in conjunction with a MP distributor.
Trying to rectify an ignition breakup over 6k rpm.
http://www.manciniracing.com/fboigboxrevl.htmlhttp://www.manciniracing.com/reeligcoun1.htmlhttp://www.manciniracing.com/fboigboxrevl.html
