94 ram 1500 speedometer comes and goes #2394117
10/28/17 01:42 AM
10/28/17 01:42 AM
sc
tjmarcus1 Offline OP
sc
As stated my 94 dodge 1500 4wd has an intermittent speedometer and odometer. I've changed the trans. sensor and the diff. sensor
Re: 94 ram 1500 speedometer comes and goes [Re: tjmarcus1] #2394257
10/28/17 03:50 PM
10/28/17 03:50 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
believe the sensor you are looking for is the speed sensor mounted on the transfer case. that would be input for the cluster and speedo reading
Re: 94 ram 1500 speedometer comes and goes [Re: tjmarcus1] #2394312
10/28/17 06:21 PM
10/28/17 06:21 PM
Georgetown de usa
E
Eggman Offline
Eggman  Offline
E
Georgetown de usa
Or the one in the rear diff could be failing
