Re: B1 originals vs -1's 345cc flow numbers?
[Re: sgcuda]
#2397340
11/02/17 03:06 PM
11/02/17 03:06 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have followed this post and the other one on bore and stroke, and have opinions based on how I went wrong on my car. First mistake was selling a 4.5 crank and using a 4.15 stroke crank. Second mistake was in not buying the best flowing heads I could afford. I went with 440-1 ported by one of the best head porters in the Midwest, dynoed 847 hp. Had I bit the bullet and bought B1Mc heads, it would have made over 1,000 hp and I may have been able to use a somewhat friendly cam that wouldn't kill parts trying to make power, which is what happened running the 440-1 heads. So IMHO go big on cubes and head flow, use a little less rpm, and a parts friendly cam.
[Re: gregsdart]
#2397351
11/02/17 03:18 PM
11/02/17 03:18 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
High RPM is hard on parts. Doesn't cost a bit more to go big on cubes once you have a good block. Big cubic inch motor w/ big heads doesn't need to work hard to make reasonable power. You can push the envelope w/ anything, but overbuild it for what you want and you'll end up w/ a lot less maintenance.
[Re: sgcuda]
#2397426
11/02/17 05:58 PM
11/02/17 05:58 PM
Posts: 14,512 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
.......go big on cubes and head flow, use a little less rpm, and a parts friendly cam. When possible, that's my preference as well.
[Re: sgcuda]
#2397451
11/02/17 07:07 PM
11/02/17 07:07 PM
Posts: 9,865 MI, usa
dvw
MI, usa
Agreed. My 572 combo is maintenance friendly, currently 200 passes with nothing but lash adjustment and oil changes. It is due for a valve spring check. Will run 9.1x in 3000 DA at 3350lbs. This -1 Indys, 285/292,.800 cam, stock Eddy carbs, and an Indy 440-25 intake. Any more power would require better stuff and more the current 7000 shift points, thus more maintenance. Doug
[Re: gregsdart]
#2397600
11/02/17 11:58 PM
11/02/17 11:58 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I have followed this post and the other one on bore and stroke, and have opinions based on how I went wrong on my car. First mistake was selling a 4.5 crank and using a 4.15 stroke crank. Second mistake was in not buying the best flowing heads I could afford. I went with 440-1 ported by one of the best head porters in the Midwest, dynoed 847 hp. Had I bit the bullet and bought B1Mc heads, it would have made over 1,000 hp and I may have been able to use a somewhat friendly cam that wouldn't kill parts trying to make power, which is what happened running the 440-1 heads. So IMHO go big on cubes and head flow, use a little less rpm, and a parts friendly cam. Greg: I think you're right. I will probably go with a 4.500 crank, but may go bigger. My Indy block seems to have strained a bit as a sprayed 605, but maybe a N/A 605 will let the cylinder sleeves hold up better? Bores are WAY out of round, maybe just worn out and not taken care of. Some of the bores measure 4.570" and not evenly around, either. And yes, I think I will look for either a used set of B1MC heads or even bite the bullet and buy a new set late spring.
[Re: sgcuda]
#2397853
11/03/17 12:49 PM
11/03/17 12:49 PM
fast68plymouth
So. Burlington, Vt.
He's not joking.
I'd use different heads........ But I'm sure you could get to 1000hp for way less $$$ than the plan you just outlined.
[Re: sgcuda]
#2398047
11/03/17 05:40 PM
11/03/17 05:40 PM
sgcuda
No turbo's. No nitrous.
1) I'm planning on running Nostalgia Pro Stock class 2) Except for superchargers, I'm going to run N/A 3) That stuff is for the guys with Fords and Chevys that struggle to make power, anyway
[image][/image]
[Re: sgcuda]
#2398061
11/03/17 06:04 PM
11/03/17 06:04 PM
fast68plymouth
So. Burlington, Vt.
A procharger would make 1000hp much easier to get....... But that set up isn't cheap either.
[Re: sgcuda]
#2398340
11/04/17 11:34 AM
11/04/17 11:34 AM
sgcuda
The 600 series head is an amazing head, but too rich for my pockets. Plus, you need a different bore spacing from what I already have. Guess I'm limited to 440-1, 572-13 or B1 heads. Not that I would exactly call that "Limited". On the B1 original or MC heads, is there any issues if I stay with shaft style rockers? I know that the paired rockers are a superior and preferred setup, but there are a lot of used B1 heads out there for sale with T&D shaft rockers. I don't plan on jumping too fast for the first set I see, but if I found a set of MC's with shaft rockers, would that be a decent setup?
[image][/image]
