383 head gasket
#2393287
10/26/17 11:18 AM
10/26/17 11:18 AM
Posts: 514 georgia
moparpro
georgia
i have a 383 eng hi po street eng with 4.280 bore what bore head gasket should i get, looking at cometic head gasket but do not see a 4.280 bore size gasket,what thickness should i get to add a little more compression,has a solid lifter cam,headers,holley 750,has 915 heads that has some work done to them.60 over flat pistons.thanks
Re: 383 head gasket
[Re: moparpro]
#2393347
10/26/17 01:39 PM
10/26/17 01:39 PM
RapidRobert
I just measured my 8519PT1 felpro blue BB head gaskets & the bore is a strong 4&1/2". they might compress to .051" same as the comparible 8553PT SB similar blue ones that compressed to .051". how far are you in the hole & what is your SCR?
Re: 383 head gasket
[Re: dogdays]
#2393517
10/26/17 08:46 PM
10/26/17 08:46 PM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
To make a good choice, you need this information........... How far down in the hole is the piston at TDC>
