Page 3 of 3 1 2 3
Re: Four Speed Overdrive Automatic [Re: 451Mopar] #2393117
10/25/17 10:24 PM
10/25/17 10:24 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Originally Posted By 451Mopar
The J.W Performance Ultra Bell makes the conversion a bit easier.
Hmm. The Ultra Bell looks interesting. The JVX reminds me of the Trans-Dapt adapters that used to pretty much adapt anything to anything. Looks like the current offerings are pretty slim.
Re: Four Speed Overdrive Automatic [Re: DaveRS23] #2393417
10/26/17 04:27 PM
10/26/17 04:27 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Originally Posted By DaveRS23
Looks like the biggest down side to putting a GM based tranny in your Mopar is money. The GM based kits look to cost over a grand more than the Mopar based stuff.
That would be the first time ever a GM part was more money than Moparts...
Re: Four Speed Overdrive Automatic [Re: 6PakBee] #2393663
10/27/17 02:34 AM
10/27/17 02:34 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Ultra Bell is the way to go. Just used one to bolt a 46RH behind a 512 stroker.
Nothing special done to the transmission either other than a re-freshening. Seems to be holding up just fine.
Re: Four Speed Overdrive Automatic [Re: MarkZ] #2393762
10/27/17 12:09 PM
10/27/17 12:09 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
So you cut back to the edge of the front pan rail? From the Ultra Bell literature it locates off the front pump. Does it fit over the face of the pump? Do you have to dial it in like you would a manual bell housing? It's shame you didn't have a picture from the front with the bell installed. That looks clean.
Re: Four Speed Overdrive Automatic [Re: 6PakBee] #2393776
10/27/17 12:35 PM
10/27/17 12:35 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Here is mine I put behind my 512,
Re: Four Speed Overdrive Automatic [Re: 6PakBee] #2393781
10/27/17 12:37 PM
10/27/17 12:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
a
Re: Four Speed Overdrive Automatic [Re: CSK] #2393792
10/27/17 01:02 PM
10/27/17 01:02 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
So the machined surface of the Ultra Bell bolts up against the as-cast face of the front pump. Wouldn't you run into some parallelism issues as the front pump face isn't a machined surface?
Re: Four Speed Overdrive Automatic [Re: CSK] #2393793
10/27/17 01:04 PM
10/27/17 01:04 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
540", 3.91 gears, and able to cruise 75mph on the Interstate. The only way to fly!
Master, again and still
Re: Four Speed Overdrive Automatic [Re: 6PakBee] #2393926
10/27/17 06:59 PM
10/27/17 06:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the front side of the pump is machined, the JW bell is made for many applications, it is used on MANY race,street cars with no problems.
Re: Four Speed Overdrive Automatic [Re: CSK] #2394179
10/28/17 11:32 AM
10/28/17 11:32 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thank you for setting the record straight. I was just confused.
Page 3 of 3 1 2 3
