72-74 cuda reverse light grommet firewall location #2390420
10/20/17 07:07 PM
10/20/17 07:07 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Does anybody have a picture of where the hole for the grommet for the dash mounted reverse light for a 73 cuda is. I can find 70 and 71, but nothing later. Or is it the same for 71 up? Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 72-74 cuda reverse light grommet firewall location [Re: 73cuda340] #2392611
10/24/17 10:32 PM
10/24/17 10:32 PM
clarks summit pa
clarks summit pa
Bump
Re: 72-74 cuda reverse light grommet firewall location [Re: 73cuda340] #2393092
10/25/17 09:42 PM
10/25/17 09:42 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I want to follow this cause doing a budget build 72 cuda with my son. I would like to know is, cant seem to find where the reverse light goes in his 72 Cuda. It's an original 340- 3 speed car. BS so its a Cuda. Hope you don't mind me jumping in on your post. Would think 72-74 are the same. doesn't just come thru the wiring block?
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 72-74 cuda reverse light grommet firewall location [Re: hulmule] #2393917
10/27/17 06:37 PM
10/27/17 06:37 PM
clarks summit pa
clarks summit pa
There is a grommet that goes through the firewall and plugs into the wiring block for the dash mounted reverse indicator light. The three speeds didn't come with the reverse light, only the 4 speeds.
Re: 72-74 cuda reverse light grommet firewall location [Re: 73cuda340] #2393920
10/27/17 06:41 PM
10/27/17 06:41 PM
clarks summit pa
clarks summit pa
https://board.moparts.org/ubbthreads/ubbt...t-location.html
Here's a post from the past to help you with the location of the light on the dash frame.
Re: 72-74 cuda reverse light grommet firewall location [Re: 73cuda340] #2395054
10/29/17 09:38 PM
10/29/17 09:38 PM
clarks summit pa
clarks summit pa
Anyone have a 72-74 4 speed cuda that can check?
Re: 72-74 cuda reverse light grommet firewall location [Re: 73cuda340] #2403205
11/13/17 08:28 PM
11/13/17 08:28 PM
clarks summit pa
clarks summit pa
Nobody?
