Remote Battery Disconnect on ground side? #2392445
10/24/17 05:44 PM
10/24/17 05:44 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I want to put a remote battery disconnect in Dad's Duster while I'm moving the battery to the trunk.
In his 69 Dart I bought a unit that works perfectly but haven't been able to find it again.
What would happen if you used a Ford solenoid directly off the ground terminal and from the other side of the solenoid to a ground point.
Then run a small ground wire from the battery to a remote toggle switch...leaving the switch back to the small terminal on the solenoid basically duplicating what is done with the hot wire in a starter installation...
Any reason this doesn't work??? work
It would be cheap and I don't need a mechanical disconnect for racing purposes anyway...
All I'm really looking to do is toss a switch after I shut the car off that disconnects the battery completely...I'm not worried about isolating the alternator while doing this...
Thoughts???
...FAFO...
Re: Remote Battery Disconnect on ground side? [Re: skicker] #2392457
10/24/17 06:02 PM
10/24/17 06:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Just make sure the relay is rated for continuous duty with a high enough amperage rating, not just spot duty like a starter solenoid. make sure to fuse the trigger wire at the battery.
Doug
Re: Remote Battery Disconnect on ground side? [Re: skicker] #2392639
10/24/17 11:22 PM
10/24/17 11:22 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Do it right. This says for GM but it works on anything. It cured my hot start problem and made the car NHRA legal. http://madelectrical.com/catalog/st-1.shtml
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
