Dome light glows when map light is off #2392170
10/24/17 02:32 AM
10/24/17 02:32 AM
Illinois
3
3XBlack6packGTX Offline OP
Illinois
Hopefully i can l describe this. I have a 70 gtx with Rallye gauge cluster and the dome light, on the roof, glows very softly when the headlights are on and dimmer switch is turned down low. Not sure why this happens. If I turn the dimmer all the way on the dome light turns on. I also noticed that my map light wants to dim with the dimmer switch.
Any one seen this before?
Re: Dome light glows when map light is off [Re: 3XBlack6packGTX] #2392326
10/24/17 01:51 PM
10/24/17 01:51 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
Sounds like a ground issue to me. Run into similar problems on cars that lost a ground.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Dome light glows when map light is off [Re: hulmule] #2392334
10/24/17 02:00 PM
10/24/17 02:00 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Also check all the fuses, easy to do but people miss that.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Dome light glows when map light is off [Re: 3XBlack6packGTX] #2392483
10/24/17 07:03 PM
10/24/17 07:03 PM
Illinois
3
Illinois
I'm sure that's the case, Going through that process now. Thanks
