VENT TUBES ON YOUR CARBS.......... #239056
02/28/09 06:53 PM
02/28/09 06:53 PM
State of confusion
Thumperdart Offline OP
State of confusion
I was talking to a member on here about my bowl vent tubes and the possibility of vaccum pulling fuel from them at speed so, what do you guys do if anything to eighther extend or re-locate to avoid this issue if it even is one.....Thankxx....
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239057
02/28/09 07:07 PM
02/28/09 07:07 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Just a thought... if you're running out of fuel, its hard to believe the level is high enough that it can pull over...espescially in high gear..
Rem
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239058
02/28/09 07:16 PM
02/28/09 07:16 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
run a piece of rubber fuel line from one to the other looped about 3" high in the center with a slot cut in to the top of the high point of the tube
Re: VENT TUBES ON YOUR CARBS.......... [Re: mopardad] #239059
02/28/09 07:25 PM
02/28/09 07:25 PM
State of confusion
State of confusion
I`m looking at any and every possibility to explain the 99 jets in this thing. I did have rubber extensions and now I tied the two together with a long slit 1/8th wide in the BOTTOM of the bend so it clears the air filter top/scoop.
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239060
02/28/09 07:32 PM
02/28/09 07:32 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
What size is the high speed air bleed?
Too large will cause lean condition on Dominator at wot.
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239061
02/28/09 07:34 PM
02/28/09 07:34 PM
with the air cleaner on it normally wouldn't be an issue. and you don't want the slit on the bottom since the incoming air (to the carb) could potentially create a siphon effect on it.
without the air cleaner on is when you would normally see a problem, mostly at high speed from the air rushing into the scoop and over the vent tubes. that's when a tube connecting the vents and a narrow slit on the top or side side might help.
Re: VENT TUBES ON YOUR CARBS.......... [Re: mopardad] #239062
02/28/09 07:42 PM
02/28/09 07:42 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
dom are you running a dominator or 4150? when i ran the 4150 car was quick out of the hole but slowed on big end,went to dominator car left good but came on the big end and picked up et and mph..never went back to 4150
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239063
02/28/09 07:56 PM
02/28/09 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like this
Re: VENT TUBES ON YOUR CARBS.......... [Re: MR_P_BODY] #239064
02/28/09 07:59 PM
02/28/09 07:59 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Looks like this
is that pic from the 50s?
Re: VENT TUBES ON YOUR CARBS.......... [Re: Quicktree] #239065
02/28/09 08:13 PM
02/28/09 08:13 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
we run 90 degree spark plug boots and put a tube drilled holes in tube across .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: VENT TUBES ON YOUR CARBS.......... [Re: mopardad] #239066
02/28/09 08:14 PM
02/28/09 08:14 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Same here, and if the float sticks is less likely to burn your car up, and it dumps into the carb. Not good for the cylinders, but it's the lesser of evils I think.
Re: VENT TUBES ON YOUR CARBS.......... [Re: ToddP] #239067
02/28/09 08:14 PM
02/28/09 08:14 PM
State of confusion
State of confusion
I`m running an 8082-3 hp 1050 dominator w/ 25 hi-speed bleeds in the rear and I believe 31`s ft. w/90`s and a 3.5 pv-and 99`s w/out.
Re: VENT TUBES ON YOUR CARBS.......... [Re: Quicktree] #239068
02/28/09 08:25 PM
02/28/09 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like this
Why do you say that Tony
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239069
02/28/09 08:35 PM
02/28/09 08:35 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Try .025"s in the front as well.
This may help.
Re: VENT TUBES ON YOUR CARBS.......... [Re: ToddP] #239070
02/28/09 08:43 PM
02/28/09 08:43 PM
PA
moparacer Online content
moparacer  Online Content
PA
I always thought that would change the fuel curve?
I have ran all sorts of hood scoops and air filters and carb combs never had to do that hose trick...
Re: VENT TUBES ON YOUR CARBS.......... [Re: ToddP] #239071
02/28/09 08:48 PM
02/28/09 08:48 PM
State of confusion
State of confusion
We tried smaller bleeds in the ft at the chassis dyno and it went dead rich but, havn`t tried it at the track yet.....was told that`s WAY too rich but if I race on the 8th I`ll try it.
Re: VENT TUBES ON YOUR CARBS.......... [Re: 10 o to go] #239072
02/28/09 08:51 PM
02/28/09 08:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
don
I'm sure that looks better but if you needed more
vertical column you would have to loop it up, the
loop has about 4" more vertical column
Re: VENT TUBES ON YOUR CARBS.......... [Re: moparacer] #239073
02/28/09 08:53 PM
02/28/09 08:53 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
It should, that is change the fuel curve in the primarys to not run lean at wot
I would also measure the kill bleed in the metering block.
Also how many emulsion bleeds in the main well are drilled 2,3,or 4?
does the metering block use a tube in the main well to feed the idle circuit?
I run my dominator high speed bleeds the same size as the kill bleed in the metering block.Same size in primary and secondary .026"
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239074
02/28/09 09:05 PM
02/28/09 09:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dom, is your scoop sealed, if so you wont see a vacumn
in the scoop area, specially on top end, that area will
be under a slight pressure, about 5"-8" of water at
your speed. The loop tube is for a hard leaving car,
when you launch the fuel sloshes up and out of the vent
falling into the carb causing the carb to go dog rich
EDIT
also a set up that didnt have a air cleaner and
usually no hood, the air passing over the carb would
suck fuel out of the vents and spray on the windshield
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239075
02/28/09 09:09 PM
02/28/09 09:09 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
You will no doubt have to take main jet out after reducing the hs air bleed size.
It seems like your current carb set up is lean on the primary and rich on the secondary.
Also I would measure the power valve channel restrictors to determine proper jet stagger.
99 is a very big jet.
