72-74 cuda reverse light grommet firewall location
#2390420
10/20/17 07:07 PM
10/20/17 07:07 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Does anybody have a picture of where the hole for the grommet for the dash mounted reverse light for a 73 cuda is. I can find 70 and 71, but nothing later. Or is it the same for 71 up? Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: 72-74 cuda reverse light grommet firewall location
[Re: 73cuda340]
#2393092
10/25/17 09:42 PM
10/25/17 09:42 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
I want to follow this cause doing a budget build 72 cuda with my son. I would like to know is, cant seem to find where the reverse light goes in his 72 Cuda. It's an original 340- 3 speed car. BS so its a Cuda. Hope you don't mind me jumping in on your post. Would think 72-74 are the same. doesn't just come thru the wiring block?
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#2393917
10/27/17 06:37 PM
10/27/17 06:37 PM
73cuda340
clarks summit pa
There is a grommet that goes through the firewall and plugs into the wiring block for the dash mounted reverse indicator light. The three speeds didn't come with the reverse light, only the 4 speeds.
[Re: 73cuda340]
#2395054
10/29/17 09:38 PM
10/29/17 09:38 PM
73cuda340
clarks summit pa
Anyone have a 72-74 4 speed cuda that can check?
