Nice timing cover for big block #2389955
10/19/17 06:47 PM
10/19/17 06:47 PM
nc
E
earthmover Offline OP
E
nc
Anybody use the 440 source cover are the good quality or leak like crazy..need a nice cover for the new build any recommendations if the source stuff is junk
Re: Nice timing cover for big block [Re: earthmover] #2389957
10/19/17 06:55 PM
10/19/17 06:55 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Made in China......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Nice timing cover for big block [Re: Old School] #2389961
10/19/17 06:59 PM
10/19/17 06:59 PM
nc
E
E
nc
Just looked at the milodon 65650 looks nice
Re: Nice timing cover for big block [Re: earthmover] #2389962
10/19/17 07:00 PM
10/19/17 07:00 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Do you want a new stamped steel part like a factory cover, or something like an aluminum upgrade?
Re: Nice timing cover for big block [Re: earthmover] #2389964
10/19/17 07:01 PM
10/19/17 07:01 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
The Milodon #65650 is a decent steel cover for the money.
Re: Nice timing cover for big block [Re: Nitrojunkee] #2389965
10/19/17 07:04 PM
10/19/17 07:04 PM
nc
E
E
nc
Steel is fine with me aluminum is nice but I'm not going to throw a ton of money on it ..i just don't want any leaks if possible
Re: Nice timing cover for big block [Re: earthmover] #2389983
10/19/17 07:45 PM
10/19/17 07:45 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Made in China......
so are those Walmart sneakers you're wearing !!
Re: Nice timing cover for big block [Re: earthmover] #2389986
10/19/17 07:55 PM
10/19/17 07:55 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
I have the Milodon 65650 and it doesn't leak, it's a nice rigid piece.
Re: Nice timing cover for big block [Re: Nitrojunkee] #2389989
10/19/17 08:01 PM
10/19/17 08:01 PM
nc
E
E
nc
Thank you I think ill order that tonight
Re: Nice timing cover for big block [Re: earthmover] #2390028
10/19/17 09:27 PM
10/19/17 09:27 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I like my Indy cover.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Nice timing cover for big block [Re: Stanton] #2390088
10/19/17 11:32 PM
10/19/17 11:32 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Originally Posted By Stanton
Made in China......
But it's nothing to switch out a pair of sneakers grin
Re: Nice timing cover for big block [Re: earthmover] #2390122
10/20/17 12:46 AM
10/20/17 12:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Indy covers don't fit under stock water pumps.
Re: Nice timing cover for big block [Re: Stanton] #2390130
10/20/17 01:01 AM
10/20/17 01:01 AM
PA.
"Little"John
"Little"John
PA.
Watch the stock ones or cheap chrome ones. I always use a cam button to limit thrust and if you watch the cheapie they will bulge out
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Nice timing cover for big block [Re: earthmover] #2390158
10/20/17 01:56 AM
10/20/17 01:56 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have a Keith Black. But it's a gear drive as well
Re: Nice timing cover for big block [Re: earthmover] #2391695
10/23/17 11:18 AM
10/23/17 11:18 AM
an8sec70cuda Offline
I use factory covers on all my stuff. shruggy
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Nice timing cover for big block [Re: earthmover] #2391770
10/23/17 01:24 PM
10/23/17 01:24 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm using the 440 Source cover on my motor with a roller cam. Just clocked over a 1,000 miles on it this year and still bone dry. Website claims they're US made.
Re: Nice timing cover for big block [Re: MarkZ] #2391819
10/23/17 02:52 PM
10/23/17 02:52 PM
I saw one of 440 Source polished aluminum fabricated covers in their blem section, I ask about it and was told it was return do it not being exactly flat.
I'm building a high dollar all new parts 572 C.I. Hemi motor for show car guy that wants everything chromed or polished, I had one of AR Engr. aluminum timing cover on the shelf but the stock water pump won't clear it so I order two of the fabricated polished aluminum 440 Source ones, one of them rocked on the hemi block and one didn't confused I called them about the bent one and they told me all of them will be slightly bent due to heat warpage when they are welded up work They said to bolt the bent one on the block to see if it will flatten out and seal up shruggy
I installed the front seal in the other non bent one and it is bent now shock runaway
I'm going to bolt it on and see if I can get a .0015 feeler gauge to slide in all the way around it without a gasket, if I can I will use a gasket and some adhesive silicone gasket sealer to seal it up and pray it doesn't leak luck
IHTHs thumbs
Re: Nice timing cover for big block [Re: Cab_Burge] #2391826
10/23/17 03:01 PM
10/23/17 03:01 PM
AndyF Online content
AndyF  Online Content
The aluminum water pump housing will clear my billet timing chain cover. You might need to grind a little bit on the back side of a cast iron water pump housing to get it to clear but who uses a cast iron water pump housing anymore?
Re: Nice timing cover for big block [Re: AndyF] #2391832
10/23/17 03:04 PM
10/23/17 03:04 PM
Neither one of my Mopar brand aluminum water pump housing would clear on that World block shruggy
I used yours on one of my roller cam race motors for the thrust button, it has a 1/4 thick front motor plate on it up
Re: Nice timing cover for big block [Re: earthmover] #2391839
10/23/17 03:09 PM
10/23/17 03:09 PM
Should bolt right on. I've been using aluminum water pump housings with my billet covers for years. Here is a picture.
