Four Speed Overdrive Automatic
#2389878
10/19/17 04:27 PM
10/19/17 04:27 PM
Posts: 10,723 North Dakota
6PakBee
North Dakota
I'm seriously considering using a JVX adapter kit and putting a four speed automatic behind a stock 375 HP 440. It looks like a 42RH or 46RH would be suitable. I know nothing about the torque capabilities of either unit. Would the 42RH be adequate or would the 46RH be a better choice? Again, keep in mind my experience stopped with the late 70's Torqueflite so this is all uncharted territory.
Re: Four Speed Overdrive Automatic
[Re: 6PakBee]
#2389891
10/19/17 04:45 PM
10/19/17 04:45 PM
Posts: 1,511 AZ
Mike P
AZ
The 46RH were based on the 727 Torqueflites and I believe the 42s are based on the lighter duty 904s. They didn't put 904s behind Big Blocks for a reason.
I used a 46RH in the 37 Dodge PU that I just got running. I'm impress enough with it I'm considering building another one to replace the 4 speed in my 57 Plymouth.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: Kern Dog]
#2389926
10/19/17 05:55 PM
10/19/17 05:55 PM
Posts: 3,080 Michigan
A727Tflite
A9xx evolved in to 42/44RH then RE. A727trans evolved in to 46/47/48 RH/RE.
The numeric coding was adapted by most of the OE's to show number of speeds and relative torque capacity.
A500/518/618 are useless designations when you compare to the industry example above.
46 = 4/number of speeds and 6/relative torque capacity. 47 has same number of speeds as the 46 but more torque capacity, 48 same number of speeds but more torque capacity.
As for what to use, you don't mention what vehicle you are going to install the unit in. A passenger car used for normal driving would have no issues with a 42/44. It offers a lower first and second gear than the larger units, is lighter too. All of them have lockup. Consider that the 44 was used in Jeeps and light truck, so if the unit is built correctly you should have no issues.
If you are going to flog the unit more than drive it you may want to consider the large box.
[Re: 6PakBee]
#2389935
10/19/17 06:15 PM
10/19/17 06:15 PM
A727Tflite
The three speed evolved in to the four speeds with the addition of the over drive assembly.
[Re: 6PakBee]
#2389941
10/19/17 06:17 PM
10/19/17 06:17 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I'm seriously considering using a JVX adapter kit and putting a four speed automatic behind a stock 375 HP 440. It looks like a 42RH or 46RH would be suitable. I know nothing about the torque capabilities of either unit. Would the 42RH be adequate or would the 46RH be a better choice? Again, keep in mind my experience stopped with the late 70's Torqueflite so this is all uncharted territory. You have to cut up the torsion bar x member, bang on the floor board & make a custom x member.
[Re: 6PakBee]
#2389988
10/19/17 07:59 PM
10/19/17 07:59 PM
Posts: 12,122 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I put a 518 behind the Hemi last year. There is room for the 518s and there are plenty of them. The cores cost about the same and there is not a lot of money difference to rebuild each, so there is not much incentive for you to go with the lighter 500.
I did not have to do any crossmember cutting putting one into my 70 Cuda. There was one place that needed a 2 inch or so dent make in the floor board for clearance. I bought a fabbed crossmember, but they are not complicated to make. I am just not good at fabrication, so buying one already made was easier.
You will likely have the thing rebuilt before you put it in, so which one you start with (46, 47, 48) won't matter much in the end. As long as it's an RH (not RE) which had the small oval 2 or 3 pin connector.
The earliest 518s had the 2 pin connector. After a couple of years, they added the lock-up torque converter and the connector became a 3 pin to accommodate it.
I went with the non lock-up because there is a much better selection of torque converters. But for a milder street car, that might not be an issue and there can certainly be an argument made for the lockup. And they made the lock-up version longer, so there actually should be more of them.
If you have a competent 727 tranny guy locally, I feel the best bet is to grab a core at a salvage yard ($200+/-) and have it built the way you want it. That can be anywhere from $600 to $1,200.
Based on my experience, the cost of the swap could be anywhere from $1,000 to $2,500.
There are a number of threads around that detail the swap. One has step by step pictures. It is bit involved, but not too bad.
Master, again and still
[Re: 6PakBee]
#2390016
10/19/17 08:58 PM
10/19/17 08:58 PM
Posts: 2,940 GA
roadrunninMark
GA
The 42RH is a smaller case and uses less HP to drive it. Problem is in stock config it isn't very strong. You can build it to handle the power. It just costs more. a stock 375hp 440 is easily doable with a hopped up 42RH. Another nice thing about the 42 is the better gear spread, first gear is a 2.74 vs. 2.45 first gear. Second is 1.54 vs. 1.45. OD is same on both at .69. I am building one to go behind a small block that should have about 400hp. SMR is a great company to get parts/info. Also PATC has parts and reasonable prices on torque converters, I just ordered mine from them. Here is a great thread on the whole install and comments/questions...and of course wiring it up. GDonovan here has a great schematic too. http://www.cuda-challenger.com/cc/index.php?topic=84774.0
[Re: 6PakBee]
#2390053
10/19/17 10:31 PM
10/19/17 10:31 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A 440 doesn't need a lower first gear than 2.45, so that point is moot.
[Re: Supercuda]
#2390112
10/20/17 12:18 AM
10/20/17 12:18 AM
Posts: 43,206 Bend,OR USA
Cab_Burge
My old M.W. stocker like the Mopar 2.77 low gear set at the drags That car ran low elevens back in the late 1980s on nine inch tires, that car liked the low gear set a lot. It out ran every Mopar M.W stocker in B/SA at the 1988 NHRA World finals I had heard of several other M.W. racers in 1964 cars that said that same gear set in their cars spun the tires But they didn't change the rear gear ratio like I did when I did that gear swap in the tranny If you don't test, you don't learn Some times you have to go sideways or backup to find what does work in testing
[Re: DaveRS23]
#2390132
10/20/17 01:03 AM
10/20/17 01:03 AM
CSK
Pattison Texas
There are a number of threads around that detail the swap. One has step by step pictures. It is bit involved, but not too bad. no cutting on an E body might be true, not so on my 1968 Charger.
[Re: A727Tflite]
#2390263
10/20/17 12:47 PM
10/20/17 12:47 PM
6PakBee
North Dakota
...As for what to use, you don't mention what vehicle you are going to install the unit in.... Sorry, this would be going into a 1968 Charger. Thanks to everybody who commented. There is no substitute for this type of spirited discussion with a multitude of opinions and real world experience.
[Re: DaytonaTurbo]
#2390326
10/20/17 03:38 PM
10/20/17 03:38 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The 904 evolved into the 500 which was later renamed the 42RH. The 727->518->46RH. 1996+ went to the RE models which are useless to you so make sure you don't get one of those.
I have read others who went to the GM 4 speed autos for better/cheaper aftermarket support and a smaller physical size to not have to cut. One day when I get off of my ass, I want to get one of those A41 4 speed kits from Silver Sport. They are based on the GM 700R4.
[Re: Kern Dog]
#2390361
10/20/17 05:11 PM
10/20/17 05:11 PM
Cab_Burge
One of my local customers did that conversion, took out a good 727 and put in a GM 250 4 speed over drive, lots of money and problems making it work and shift the way he wants it to. Two different converters and lots of labor so far and he is still not happy This went into a 1963 M.W. Fury with 3.23 gears, he said originally he wanted better mileage, it is a real nice drive to show car and doesn't get driven over 3000 miles a year. He later change the rear gear ratio from 3.23 to 3.55 to make it accelerate better The parts and pieces cost a bunch over what he will save in fuel cost if he doesn't start driving it over 30,000 a year My message is be careful of what you do to your car to make it better
[Re: Kern Dog]
#2390403
10/20/17 06:47 PM
10/20/17 06:47 PM
Posts: 25,827 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Wise decision, the 700R4 is superior in all the areas discussed.
