Re: Backfiring through the exhaust [Re: Crizila] #2389269
10/18/17 12:32 PM
10/18/17 12:32 PM
#1 on the hit parade should be to get the battery problem fixed.
X2 then (charged up (from a charger not the alt) take it out & if still bad change the coil, put in any one from your stash just for a test (with a ballast if need be). EDIT vac leak is another potential & you did change plugs correct? plug wires would be further down on the list
Re: Backfiring through the exhaust [Re: mopar dave] #2389577
10/18/17 10:49 PM
10/18/17 10:49 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
after running my new plugs a while the pop out the exhaust came back. I discovered that I had the magnetic plug hooked wrong. ya see with MSD the orange wire is the positive and on an Ice ignition box the purple is positive. Reversed the plug, reset timing and so far no pop out exhaust.
Re: Backfiring through the exhaust [Re: 1968RR] #2389689
10/19/17 02:43 AM
10/19/17 02:43 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Mine is a stock 1964 points ignition. Coil, condenser what's left ? I guess I'll just start throwing money at it till it stops .
Re: Backfiring through the exhaust [Re: rowin4] #2389773
10/19/17 12:28 PM
10/19/17 12:28 PM
Mt Morris Michigan
Mt Morris Michigan
Well, first I would check all your grounds because its most likely electrical issue causing that. Next I would take a hard look at your distributor. The reason mine was popping was because with the polarity of the pickup coil reversed it put the rotor out of phase. Might want to check that. Maybe you just need a new cap and rotor. I'm sure its something in your electrical system between dist. and spark plugs to ignition box imho.
Re: Backfiring through the exhaust [Re: 1968RR] #2389774
10/19/17 12:30 PM
10/19/17 12:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Do any of you guys have power brakes?
Re: Backfiring through the exhaust [Re: Challenger 1] #2389775
10/19/17 12:34 PM
10/19/17 12:34 PM
Mt Morris Michigan
Mt Morris Michigan
I do not have power anything.
Re: Backfiring through the exhaust [Re: 1968RR] #2389858
10/19/17 03:25 PM
10/19/17 03:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had asked when it did it because if it backfires when letting off the gas then I would look for an exh leak at a header gasket as it will suck in air on decell and can cause it. If it does it when stepping on the gas and feels like it misses at the same time then I would be looking at the ign system real close. Or does it do is just sitting there idling ? Ron
Re: Backfiring through the exhaust [Re: 1968RR] #2389867
10/19/17 03:46 PM
10/19/17 03:46 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I swapped out the battery and the plugs and the backfire went away. I was surprised, considering that I didn't replace the two plug wires that lacked continuity. I guess that the spark is able to arc across whatever gap is in the wires with a good battery. Of course, I'll be replacing the wires soon.
On a side note: my engine seemed to like the NGK V-Power plugs that I used to have in there a lot more than the Autolite Racing plugs that I swapped in.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Backfiring through the exhaust [Re: 1968RR] #2389932
10/19/17 06:09 PM
10/19/17 06:09 PM
When motors talk to me I listen, especially on spark plugs up
Most racing plugs are COLD, some are to cold for pump gas on the street tsk grin
