Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Project VIP to drag week 2017 [Re: jyrki] #2387811
10/15/17 06:24 PM
10/15/17 06:24 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Yes, got the pistons in a couple of weeks ago, the first set they sent where .040 to big, sent back got the correct size in. This is all after sending the chamber mold in of the fbs heads. With all details, one delay after another.
Re: Project VIP to drag week 2017 [Re: mprhound] #2387843
10/15/17 08:08 PM
10/15/17 08:08 PM
birdtracker Offline
birdtracker  Offline
who made your pistons and what bore size? thanks Birdtracker
Re: Project VIP to drag week 2017 [Re: jyrki] #2387897
10/15/17 10:34 PM
10/15/17 10:34 PM
Texas
mprhound Offline
mprhound  Offline
Texas
4.400
Diamond
Did my pistons
I had to have a big inverted dome yo bring the compression down to 11.8 to one
My heads have 53 cc chambers
Re: Project VIP to drag week 2017 [Re: jyrki] #2388010
10/16/17 03:29 AM
10/16/17 03:29 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Thanks for the compliments!
The valves were titanium, age unknown. One thing with them is the heat, don't think they move the heat out to effectively with regular seats.
Our pistons are Diamond too, have the part number, I guess they can get the valve locations and angles with that number.
Plynouth VIP '67 TT IC EFI
Re: Project VIP to drag week 2017 [Re: jyrki] #2388138
10/16/17 01:31 PM
10/16/17 01:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've been told that you should have Magnezium (SP?) bronze valve seats with Ti valves work
Re: Project VIP to drag week 2017 [Re: Cab_Burge] #2388214
10/16/17 03:45 PM
10/16/17 03:45 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is that the same as beryllium seats?
Kevin
Re: Project VIP to drag week 2017 [Re: jyrki] #2389143
10/18/17 03:59 AM
10/18/17 03:59 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Anyway, have to renew the valves and since we only plan to wind to about 7000, the stainless should work great.
Re: Project VIP to drag week 2017 [Re: jyrki] #2389156
10/18/17 07:23 AM
10/18/17 07:23 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Go with Inconel. I've noticed lash can stay tighter and consistent with varying temperature compared to stainless. My stainless valves always came out purple and the seating area of the valves always looked imprinted.
The Inconel valves never looked abnormal. They are heavy.
Re: Project VIP to drag week 2017 [Re: TRENDZ] #2389164
10/18/17 07:56 AM
10/18/17 07:56 AM
birdtracker Offline
birdtracker  Offline
Trendz: where did you buy your valves? Birdtracker
Re: Project VIP to drag week 2017 [Re: jyrki] #2389178
10/18/17 09:36 AM
10/18/17 09:36 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I got them through my machine shop. C&S performance(Butler Wisconsin), but from what I remeber, they were 1.88'' BBC valves turned down to 1.81". I believe there was some stem work also, but I didn't do it myself, so take it for what its worth. I don't think I was ever told who made them, but I did get my old stuff back in a Manley box.
Re: Project VIP to drag week 2017 [Re: jyrki] #2389293
10/18/17 01:18 PM
10/18/17 01:18 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Manley severe duty Inconel, have lasted great so far. When facing the valves you can tell they are high quality.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Project VIP to drag week 2017 [Re: jyrki] #2389692
10/19/17 03:17 AM
10/19/17 03:17 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
One problem with the FBS heads is that the valves are LONG. You just don't take something and cut it to fit, they are almost 7".
Re: Project VIP to drag week 2017 [Re: jyrki] #2389708
10/19/17 07:21 AM
10/19/17 07:21 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You can have anything made. Mine were done that way because they were readily available shelf items and needed minimal modification. I had the most basic, close to "standard" heads. I realize that what you are running is more exotic. Just more of a reason to go with the better parts.
EFIdart has predator heads. I'm not real sure about the valve sizes used in those...
Anyway, you both have very impressive cars. I applaud your perseverance. You have a lot of fans here!
Re: Project VIP to drag week 2017 [Re: jyrki] #2389832
10/19/17 02:16 PM
10/19/17 02:16 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
11223 Manley is what is in my exhausts, 6.7" long. 2.45" intake and 1.88" exhaust.
Ill see if I can find a part number for my Ti intakes.
Re: Project VIP to drag week 2017 [Re: Twostick] #2389853
10/19/17 03:03 PM
10/19/17 03:03 PM
Kevin
That is the proper name up
My memory was not accurate when I wrote that blush realcrazy
Re: Project VIP to drag week 2017 [Re: Cab_Burge] #2389890
10/19/17 04:42 PM
10/19/17 04:42 PM
dogdays Offline
dogdays  Offline
Beryllium copper is used for valve seats. It is only 2% beryllium, all that is needed, I guess.
When titanium valves are mentioned, I think of Del West Engineering. They have a very good reputation. Their titanium valves are one piece forgings. They can do hollow stems and even sodium filled stems. They have a European branch at Roche, Switzerland.
R.
Why titanium? It's strong as steel at half the weight. Titanium has a higher melting point than steel.
(The SR-71 spy plane had a titanium skin because neither stainless steel nor aluminum would retain their strength or not melt at very high speeds. This was reported about as soon as the planes were declassified.)
Re: Project VIP to drag week 2017 [Re: dogdays] #2389931
10/19/17 06:04 PM
10/19/17 06:04 PM
Speaking of the SR71 we use to live about 45 miles from AFB 42 at Palmdale Airport where Lockheed made all the SR71, they kept what they called the house bird at Edwards AFB, about fifteen miles to the northeast.
We went over to Edwards AFB several times on their open house days, one of the Lockheed employees acting as the spokepeson for the SR71 made a comment on one visit about the SR71 growing 14 inches longer at cruising speeds above 63,000 Ft due to air friction heat on the skin shock At that altitude or higher it is common to see -65 F outside air temps work
Lots of information shared with the public after those planes where retired up
My wife uncle help design parts on that airplane back in the day of slide rules work
Lockheed and other military contractors did a lot of Department of Defense work that developed products we still don't know about, especially from 1981 to 1989 work whistling up
Re: Project VIP to drag week 2017 [Re: jyrki] #2389978
10/19/17 07:31 PM
10/19/17 07:31 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
I do not want to invent a space shuttle again, and have no means of doing so. So, have to ask for solutions that I can afford. The car and the head s are still somewhere.. perhaps they will be here before next years drag week so that we can prepare for it....
Re: Project VIP to drag week 2017 [Re: jyrki] #2389981
10/19/17 07:41 PM
10/19/17 07:41 PM
birdtracker Offline
birdtracker  Offline
I need some 2.30 intake valves and 1.80 exhaust if anyone has some. thanks Birdtracker
Re: Project VIP to drag week 2017 [Re: Cab_Burge] #2390065
10/19/17 10:52 PM
10/19/17 10:52 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
My Dad worked in the Skunk Works for about 40 years, retired just after 2K. I got to go to a open house for employees families just before he retired. Lots of stuff he still can't talk about.
