Re: Garage Project
[Re: JDMopar]
#2385961
10/11/17 11:09 PM
10/11/17 11:09 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
She's complaining about the hidden gutter brackets, but somehow missed all of those ice thingies a foot up the roof? LOL Yea go figure... Snow guards my a$$ they're friggen leaf catchers... Well anyway the leaf guards were ordered Monday and once installed I can tear down the scaffolding on the front. I did get a few more pics...the gutter slope isn't too noticeable...
...FAFO...
Re: Garage Project
[Re: skicker]
#2386593
10/12/17 11:16 PM
10/12/17 11:16 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Tell your alter-ego to chill. OUTSTANDING work!
Old, tired, and sometimes broke down. Me, not my car...
Re: Garage Project
[Re: Shoozy]
#2386996
10/13/17 06:18 PM
10/13/17 06:18 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Re: Garage Project
[Re: RSNOMO]
#2388054
10/16/17 10:38 AM
10/16/17 10:38 AM
skicker
"The Champ"
"The Champ"
Western Md.
Tell your alter-ego to chill. (Wanna be there for that one... That's one of us...Better off you tell her... Since I was basically just waiting for the leaf guards and had loaned out a piece of scaffolding from the one I had out back I didn't really have anything to work on on the exterior...I went ahead and started adding the 6" wood walls around the porch. Scaffold came back Saturday and I completed the fascia, snow rail and gutter on the rear elevation. Eventually in front of the wood walls will be a 6' wide ramp that will lead to the basement and the existing shed. Just one more little piece of the puzzle finished... first pic is a before shot...
...FAFO...
Re: Garage Project
[Re: skicker]
#2388058
10/16/17 10:45 AM
10/16/17 10:45 AM
skicker
"The Champ"
"The Champ"
Western Md.
Here's the rest of the pics...I only have 2 more walls to go. From the corner you see at the left back 5' 6" at a 45 degree angle towards the garage and then one more 45 degree corner to against the foundation. I can finish this once the underground pipe for the Storm Water Management is installed. On a side note when building these do not mix wood you bought a year ago and new wood unless you can keep the rows the same...The new wood is so wet it is about 1/8" higher per board than what has dried out.
...FAFO...
Re: Garage Project
[Re: skicker]
#2389470
10/18/17 07:44 PM
10/18/17 07:44 PM
Superfreak
Superfreak
Yup, even pressure treated lumber does not last long in dirt.
Re: Garage Project
[Re: skicker]
#2391643
10/23/17 09:47 AM
10/23/17 09:47 AM
skicker
"The Champ"
"The Champ"
Western Md.
I worked on the west side and removed all of bracing for the temporary platform and installed the starter strip...tyvek and the last row of siding. I ended up with the bottom row of the siding 3/4" of an inch below the exterior sheathing...A little silicone inside the gap and I should have no bug or moisture problems... Picked up a cube of Brick on Thursday for the front elevation...May say screw it and install myself rather than wait on the mason... Last pic is the brick on the front of the house...I wanted them to match but that brick has been out of production since 2000. Its similar to but different than what I have...I can live with it...
...FAFO...
Re: Garage Project
[Re: skicker]
#2391646
10/23/17 09:57 AM
10/23/17 09:57 AM
skicker
"The Champ"
"The Champ"
Western Md.
Friday...Saturday and Sunday it was back to doing the ground work for the wood retaining walls and connecting the rain gutter piping together. I dug the trench for the piping and added the fall so it will drain...Damn thing need to be a little better than 3' in the ground where I had the extra dirt piled up... Really only about a foot deep after final grade is established...
...FAFO...
Re: Garage Project
[Re: skicker]
#2391649
10/23/17 10:03 AM
10/23/17 10:03 AM
skicker
"The Champ"
"The Champ"
Western Md.
Added the wood walls and started putting all the dirt I just dug out into the flower beds... Digging and tamping dirt is really a younger mans game... Hauling around wet 4x6's is no cakewalk either... Looks like I'll be adding a small section of landscape blocks in the corner the hide the tar on the foundation...
...FAFO...
Re: Garage Project
[Re: skicker]
#2393715
10/27/17 10:06 AM
10/27/17 10:06 AM
skicker
"The Champ"
"The Champ"
Western Md.
I picked up the leaf guards for the gutters and installed them front and back...Got all of the scaffolding removed from the front and started tearing down the temporary scaffold at the back. The front gutter is tied in to the Storm Water Management system...once I get the back scaffold down at the corner I can tie in the rear.
...FAFO...
Re: Garage Project
[Re: skicker]
#2393722
10/27/17 10:20 AM
10/27/17 10:20 AM
skicker
"The Champ"
"The Champ"
Western Md.
Here is a pic of how I tied the wood walls into the foundation to keep anything from moving. These 12 gauge steel clips we use at work and work perfect to tie in the wood also. Maybe the best pic I have been able to take of the front...much better without the scaffolds... Prior to finishing up working on this before winter I would still like to: Get brick completed at the front... Install posts at the back for the porch and stairs to the basement... Install the bottom layer of Tyvek and siding... Install basement windows and bars... Install basement door and light above door... At that point everything is sealed up tight and can be locked up... I still have a full kitchen remodel to complete for the wife...
...FAFO...
Re: Garage Project
[Re: skicker]
#2396039
10/31/17 01:39 PM
10/31/17 01:39 PM
skicker
"The Champ"
"The Champ"
Western Md.
I had to switch gears and begin working on the back porch where the stairs will be to the basement. In walking out the back door the distance to the bottom door is too close to run the stairs straight down along the back wall. I wanted to use a typical 7.5/12 stair riser and tread. There will now be a small area 5' wide and 4 1/2 foot long that will be the landing and then 2 steps down to an 8' long landing 3' wide with with two steps down to a corner landing with the balance of steps running down the wall towards the door. I installed the two posts for the 3' by 8' landing on Saturday. Pressure treated 6"x6"x16' posts buried 32" in the ground in Quickcrete. I used 3" of gravel under the posts and will add some more Quickcrete at the top to head water away from the post bases. Pics are a little hard to follow until I finish removing all the bracing for the temporary platform around the outside... Did I mention this was built on a hill???
...FAFO...
Re: Garage Project
[Re: skicker]
#2396559
11/01/17 11:17 AM
11/01/17 11:17 AM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I gotta say your garage is a work of art. I'm continually amazed at the attention to detail you've demonstrated through these postings.
I'm embarrassed to go out to my polebarn shop.
Very, very well done!
Lead, follow or get the hell out of the way
Re: Garage Project
[Re: skicker]
#2396972
11/01/17 09:33 PM
11/01/17 09:33 PM
Shoozy
Southern by Choice
Did I mention this was built on a hill??? I, too, live on a hill and need another building to complement my current three car attached. So when can I expect you????? Continued kudos!
Re: Garage Project
[Re: peabodyracing]
#2397532
11/02/17 10:25 PM
11/02/17 10:25 PM
skicker
"The Champ"
"The Champ"
Western Md.
Very, very well done! Thx...Much appreciated... Shooz...Are you familiar with the term SOL??? It'll take me another good solid year to finish the garage interior with some of the things I have planned and most of the winter to button up the witch's kitchen... After that I will need to pay for it...and that's where you come in... Jerry should have some free time...unless he's watching TV with Tom...he might be rubbing that purple thing... The car that is...
...FAFO...
Re: Garage Project
[Re: skicker]
#2399648
11/06/17 10:24 PM
11/06/17 10:24 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Re: Garage Project
[Re: RSNOMO]
#2440636
01/25/18 05:12 PM
01/25/18 05:12 PM
skicker
"The Champ"
"The Champ"
Western Md.
I received the final approved as built drawings back from the County today for the Storm Water Management System. I didn't document it here but it was a lot of work. Basically it stores all of the garage roof water and then drains it slowly back out. The money spent on this alone could've easily been an A body driver to kick the guts out of...maybe even a Fat B...
...FAFO...
