Does Harbor Freight sell a DECENT engine hoist? #2387390
10/14/17 04:24 PM
10/14/17 04:24 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Hard to coordinate with the local tool rental places, so I'm considering purchasing one. There is a Harbor Freight nearby, but IIRC there have been a lot of complaints about their hoists leaking, possibly other issues, too.
Any feedback available here to help with my decision? Thanks - Brad
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387408
10/14/17 04:50 PM
10/14/17 04:50 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I bought one from Jegs. I think everything comes on a boat from the same place nowadays. Mine works fine.
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387409
10/14/17 04:52 PM
10/14/17 04:52 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I bought a fold up Goodyear engine hoist years ago and like it so much when I saw a used one local for 80.00 I grabbed it for my house garage. Now I don't have to drag it 100 feet thru the gravel.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387448
10/14/17 07:10 PM
10/14/17 07:10 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
I've had my HF engine hoist for 17 years now. It has been used for many things besides lifting engines, but has had 3 different 5.9 cummins hanging from it... still works just fine
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: cagebob1] #2387478
10/14/17 09:23 PM
10/14/17 09:23 PM
BradH Offline OP
BradH  Offline OP
I'll keep looking, considering there are some very "telling" reviews of all the engine hoists on the HF website.
May have to jump thru a couple of hoops to get a rental after all.
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387529
10/14/17 11:10 PM
10/14/17 11:10 PM
Washington
madscientist Offline
Washington
I have one and it's fine. Just get the bigger model.
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387530
10/14/17 11:13 PM
10/14/17 11:13 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I've owned mine for about 7-8 years and have not had any issues.
I did bend one leg pulling out boxwood bushes from the ground but, I don't think the hoist is intended or rated for pulling boxwoods. laugh
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387624
10/15/17 09:45 AM
10/15/17 09:45 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I have one. It has always worked fine. No issues here
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387655
10/15/17 11:20 AM
10/15/17 11:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Back around 1985 I bought this one from the local tool rental without a hydraulic cylinder. I rented one just like it so many times one day asked how much to buy it and he sold me this hoist/crane without a lift cylinder for 200 bucks. That was a lot of money then and it took me months more to save up for a hydraulic cylinder.
Used it for larger V8 truck engines which are much heavier than a 440.
I have wore out 2 cylinders over the years using it. It is holding up the front of the car in this picture.
Then I bought this a few years ago from the local auto parts store, I think I gave around 190 bucks for it. I got it because it folds up and is easier to use at home and I keep my one above at work in my race shop. Used to take it home to use. I use the import one to do light duty work like lift the front of the lawn mover to clean the deck and change blades and small block engine swaps.
I feel this hoist was at it's limit in this case, would not feel comfortable doing this with a big block engine. My driveway was a little out of level which made the hoist very unstable. Nothing like my wide base breakdown model I showed above which is way better. FYI.
And when I got it in, the crane was touching the front bumper. It does not have the reach that my other crane has. A car with longer front end it would not work. I did the install by myself in a afternoon.
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387658
10/15/17 11:29 AM
10/15/17 11:29 AM
E
earlymopar Offline
earlymopar  Offline
E
I have had mine since the mid 90's and have had zero issues. The only things to consider in my opinion are whether to go with the collapsible unit or the non-collapsible. In the same tonnage range, I think the non-collapsible unit may have slightly different reach and width dimensions. Due to that, I went with the non-collapsible and when it's not going to in use for a while, I simply disassemble it. The small pile of parts leaning against my garage or shop wall are far smaller than the collapsible model when collapsed and it takes just a few minutes.
- EM
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: earlymopar] #2387680
10/15/17 12:06 PM
10/15/17 12:06 PM
BradH Offline OP
BradH  Offline OP
The complaints I see repeated about the current models they offer include things like parts not fitting correctly, incomplete parts and/or hardware packed, machine work issues, etc. I don't have the time or patience right now to deal with any of that crap and will look elsewhere for a solution to my immediate need.
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387685
10/15/17 12:11 PM
10/15/17 12:11 PM
Cincinnati, Ohio
Cincinnati, Ohio
I would keep an eye out for used one like the breakdown model I showed above.
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387691
10/15/17 12:18 PM
10/15/17 12:18 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
The smaller silver one that HF always puts on sale isn't worth it. Won't work for us. Not enough capacity or reach. The full size one isn't bad. The best thing I ever did was buy a second hand heavy duty hoist that had a leaking cylinder. Got a $60 ram from HF. They have several models, so getting a compatible one was easy. Check your local craigslist listings. You can probably score on a nice fold up one for the right price. I now have 2 hoists so I can pull the body off my Cuda without any help. And everything packs up out of the way when done.
[image][/image]
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387706
10/15/17 12:52 PM
10/15/17 12:52 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I have the 2 ton fold-able - works good so far i have had 10 years or so - like anything use as it is designed and it should be sufficient - one thing about a hydraulic cylinder when not in use it should be collapsed to its closed position. Pretty much all of the engine cranes i have seen seem to come from the same place China -just different color paint
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387718
10/15/17 01:27 PM
10/15/17 01:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My HF (Maybe it was Northern Tool?) collapsible hoist was purchased in the mid 90s. It has served well and still uses the original cylinder.
Lately, it has developed a habit of tilting to the left under load. Dangerous tilting. When we have to lift an engine rather high I stand on the left rear leg to counter the lean. The hoist is lowered as quickly as possible.
After a thorough examination I found that the hinge holes for the boom were wallowed out and allowing the arm to lean to one side. I bored the holes and made a larger pin. The lean has improved but not gone away. As best I can tell the left leg pin hole is a bit worn. This lets the leg lift, causing the rig to lean.
I plan on getting it straightened out before it gets used again.
- Stu Harmon
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: feets] #2387734
10/15/17 01:52 PM
10/15/17 01:52 PM
My HF breakdown is OK tho I did weld some gussets where the main vertical leg bolts to the base to further strengthen it.
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387768
10/15/17 03:51 PM
10/15/17 03:51 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
My HF is a yr old and the cylinder leaks like crazy other wise its ok and I got the bigger of the 2
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387779
10/15/17 04:26 PM
10/15/17 04:26 PM
AndyF Offline
AndyF  Offline
Brad, tell the wife you need a bridge crane......
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387781
10/15/17 04:32 PM
10/15/17 04:32 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I bought one for like 99 on sale... only reason I bought it. They apparently have 2 different ones. Well I got mismatched parts and holes didn't line up. So use the base for moving engine/transmissions around. Use the other parts for various things around the shop. Used the hydraulic cylinder on another hoist. So wasn't too upset in the end... but I wouldn't buy one from them again to actually use for lifting engines.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Does Harbor Freight sell a DECENT engine hoist? [Re: BradH] #2387802
10/15/17 05:43 PM
10/15/17 05:43 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a Harbor freight engine hoist from about 20-years ago. The hydraulic ram on it failed the first time I used it.
Really not the ram as much the threads for the release valve were stripped, and when I went to lower the 383 after pulling it, the release valve came all the way out drop the engine on the garage floor and crushing the oil pan. Lucky that was the only damage.
I replaced that hydraulic ram with another from a different source, and it has worked fine since then.
