Rocker pedestal Heli-coils... can't get 'em out!!! 8^( #2387270
10/14/17 11:32 AM
10/14/17 11:32 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I wanted to replace all the short rocker shaft studs on my Victors with long ones last night. I'd done this on the center pedestals only on another set before and had no problem getting the old Heli-coils out. At midnight I was still struggling to get even ONE out, and was just making a mess of things.
Before I used a pointed scribe or a small screwdriver to pry the top coil out, and then small pliers to pull out the rest. That didn't work for me on the new heads. I tried drilling one out on a spare head... only managed to butcher that one (good thing it's a spare I got relatively cheap).
I tried an easy-out, but think it puts too much pressure around the entire coil and forces it against the wall because it won't turn. Online searches turned up that there are tools that look like an arrow head on a t-handle... same concept as an easy-out, only it won't put pressure on the entire coil. Anyone use something like that successfully?
Whatever I do, it's going to need to wait since I don't see such a tool available locally and I need to finish assembling the engine for its "Date with Destiny" a week from today. Guess I'll be pulling the heads back off to finish the job after the dyno session...
Re: Rocker pedestal Heli-coils... can't get 'em out!!! 8^( [Re: BradH] #2387337
10/14/17 01:59 PM
10/14/17 01:59 PM
Did you use Loktite on them ?
If not how about using a heat gun on it first then try removing them with a pointed scribe and pliers work
Re: Rocker pedestal Heli-coils... can't get 'em out!!! 8^( [Re: BradH] #2387339
10/14/17 02:10 PM
10/14/17 02:10 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Bend out the first thread enough to get a good grip on it, pull lightly & turn it counter clockwise.
Re: Rocker pedestal Heli-coils... can't get 'em out!!! 8^( [Re: rickraw] #2387366
10/14/17 03:05 PM
10/14/17 03:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
And if you believe in Prayer say one BEFORE you start. I hate helicoils but i removed one and installed two for my Son the other day. Like its said above a small pick or screwdriver and a pair of needle nose pliers. I have a set of left handed drill bits that I was thinking about trying but it didn't come to that. We used mostly keenserts in the steel mill for thread repairs.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Rocker pedestal Heli-coils... can't get 'em out!!! 8^( [Re: pittsburghracer] #2387377
10/14/17 04:00 PM
10/14/17 04:00 PM
BradH Offline OP
BradH  Offline OP
If Edelbrock put them in with Loctite, then they have Loctite. However they didn't on the last set I did and it doesn't appear they did on these, either.
What you're all telling me to do is exactly what I'm doing (and did before successfully), but I can't manage to get behind the end of the top coil to pull it out to grab with pliers. Very frustrating...
Re: Rocker pedestal Heli-coils... can't get 'em out!!! 8^( [Re: BradH] #2387565
10/15/17 12:52 AM
10/15/17 12:52 AM
montreal, quebec,canada
7e5dartsport Offline
not sure it is a good idea, but i would use the spare head to practice and apply heat with a small nozzle on the torches to bend the top portion of the helicoil with the pick. i think you could get the helicoil red without damaging the aluminum of the head. at least, something to try...
fully legal sounds the same as full illegal...
Re: Rocker pedestal Heli-coils... can't get 'em out!!! 8^( [Re: pittsburghracer] #2387705
10/15/17 12:50 PM
10/15/17 12:50 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Heating them will be difficult. The aluminum head will suck the heat out just as fast as you can pour it in.
When I did my Thread Insert Deathmatch I found no benefit to using the Keensert style key locking insert. In instrumented testing that style (Recoil brand) did not perform as well as the Helicoil.
In torque testing it scored the same as Helicoil and better than the TimeSert.
When it came to the pull out resistance it began to yield about 10% lower than the Helicoil and ripped out of the test bar at 900 lbs less force (again, about 10%) too. In fact, it scored the same in this area as fresh threads in 6061 aluminum.
Here's a link to the testing video starting at the summary:
https://youtu.be/LpDduCVUy6w?t=28m39s
- Stu Harmon
