FiTech Fuel Injection #2386753
10/13/17 11:23 AM
10/13/17 11:23 AM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
In the brief research of I've done there has been mainly positive reviews but, also some negative. Just wondering if anyone has any personal experience with the setup or additional thoughts or opinions? Thank you in advance.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2386774
10/13/17 11:50 AM
10/13/17 11:50 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When it comes to aftermarket parts there will always be some issues with some applications. Unless all reviews are negative - which they aren't - I wouldn't shy away from using the product. Make sure you get the right unit for your application and follow the instructions and you should at least be in the ballpark. I've "heard" the tech support is a little lacking but now that the product's been on the market a while it should be improving.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2386792
10/13/17 12:15 PM
10/13/17 12:15 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My opinion is Throttle body EFI is a waste of time & money.
Re: FiTech Fuel Injection [Re: CSK] #2386906
10/13/17 03:47 PM
10/13/17 03:47 PM
dogdays Offline
dogdays  Offline
While my opinion is that throttle body injection, properly set up, is like a perfectly tuned carburetor. As most people are not competent to tune a carb perfectly, these bolt-on TBIs are very much worthwhile.
R.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2386925
10/13/17 04:29 PM
10/13/17 04:29 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I have it on my '89 Diplomat with small block stroked 360. I had mechanic install and setup and I'm happy with it. I have better starts now than with carb, which was my main reason for purchasing. I was tired of dealing with difficult idle with cold starts and even some trouble with hot starts. I think throttle response is better too but can't be certain. I may have already squeezed every bit out of the engine. I did have to return the first Fuel Command Center to Summit due to failure of the pump, but had no problems and received a new one quickly and cost free.
Facts are stubborn things.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2386928
10/13/17 04:39 PM
10/13/17 04:39 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
these are worthwhile to help you enjoy a car that otherwise would have a less than optimized carb on it. are the be all end all for performance and tuneability? NO. but its a pretty good system. don't waste time with the fuel command center.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: FiTech Fuel Injection [Re: OrangeProwler] #2386959
10/13/17 05:20 PM
10/13/17 05:20 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
But TBI is a fraction of the cost of port injection.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2386979
10/13/17 05:45 PM
10/13/17 05:45 PM
Indiana
toms Offline
toms  Offline
Indiana
I have a 528 hemi putting out over 700 hp. It runs on pump gas with radical cam 4 speed. I have the fitech 1200 hp on mine. A friend of mine has put several on before with little issues. Mine was a little harder to dial in because of it being so radical. But it is a different world as far as starting cold or warm. It learns your driving habits. As far as tech support they answered all my questions. I had no problem with them. Feel free to ask any questions.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2386983
10/13/17 05:54 PM
10/13/17 05:54 PM
Sweet5ltr Offline
Sweet5ltr  Offline
Before purchasing anything, join FiTech owners group on FB. Really get a feeling if it's for you or not, prior to getting involved.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
Re: FiTech Fuel Injection [Re: Jerry] #2386993
10/13/17 06:14 PM
10/13/17 06:14 PM
BDW Online content
BDW  Online Content
My experience exactly, makes the car just so much more enjoyable to drive.
Just got tired of all the carb related issues. So nice to jump in car and have it start immediately, hot or cold. More responsive, no stumbles.......
Re: FiTech Fuel Injection [Re: Stanton] #2387016
10/13/17 07:28 PM
10/13/17 07:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A large fraction maybe depending on who's system you go with.
The ONLY slight downfall to TBI IMHO is you are still depending on the manifold and airflow to deliver the fuel.
Port injection gives you the advantage of being able to trim fuel, cylinder to cylinder which unless emissions is your concern is not much of an advantage for the average user.
Kevin
Re: FiTech Fuel Injection [Re: OrangeProwler] #2387038
10/13/17 08:23 PM
10/13/17 08:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Only if you have sensors on each exhaust post - adding even more cost to port injection.
TBI is by far the simplest and most economical route to go.
Re: FiTech Fuel Injection [Re: BDW] #2387041
10/13/17 08:35 PM
10/13/17 08:35 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Exactly.
Re: FiTech Fuel Injection [Re: Jerry] #2387042
10/13/17 08:38 PM
10/13/17 08:38 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I don't think you shouldn't throw out bold statements like "don't waste time with the fuel command center" without providing reason. I've had no problems with mine other than a bad pump from the get go. Since then I've put many miles on mine in hot Florida and had no problem whatsoever, and it saved me a lot of money and time. Yes, there are pros and cons, but again, just throwing it out there without explanation does not help the o/p.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2387047
10/13/17 08:56 PM
10/13/17 08:56 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I installed my unit myself cleanly and as the manufacturer suggested paying attention to the details. New clean tank, 3/8 fuel line, properly returned FCC vent. I've had not issues other than needed a software update
Re: FiTech Fuel Injection [Re: OrangeProwler] #2387073
10/13/17 09:36 PM
10/13/17 09:36 PM
Middle of A Field
O
O
Middle of A Field
Thank you again everyone. I figure I'd try to get some feedback since I'm potentially considering throwing this onto a Late B-Body like a near stock 318 or 360 small block.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2387081
10/13/17 09:50 PM
10/13/17 09:50 PM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
I just got mine running this week. It does start up quick. Have not put any real miles as I rebuilt my front end and need an alignment.
I went with an in tank Aeromotive pump.
Re: FiTech Fuel Injection [Re: Stanton] #2387085
10/13/17 09:59 PM
10/13/17 09:59 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Actually no. Computers and O2 sensors are fast enough now that with engine position sensors the ECM can tell which exhaust pulse comes from which cylinder by monitoring the O2 sensor data.
That's how the ECM in new cars can throw a code to tell you which cylinder is misfiring.
Kevin
Re: FiTech Fuel Injection [Re: OrangeProwler] #2387188
10/14/17 02:19 AM
10/14/17 02:19 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My friend has a big block chevell that ran a Kinser toilet running on alcohol , 14 :1 compression .The car ran 8.70 at 150+ mph. So, he decides to buy the FITech 1200 HP set up. He don't know squat about electronic stuff but he installed it. Surprising to me now the car starts right up, idles like a stock engine, still radical but has instant throttle response and still running alcohol. The FITech did slow the car down .3 He says it is because the FITech doesn't flow as much as CFM as the toilet did. Now I must say this car repeats every run down to the thousants, 60 ft. , 1/8 and 1/4 mile. He's even going rounds . Whats with that? I should have bought the FITech instead of the Holley dominator. I can see one in my future.
Re: FiTech Fuel Injection [Re: Jerry] #2387197
10/14/17 03:08 AM
10/14/17 03:08 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I have to disagree, way simpler installation than frame-mounted pumps or for cars where in-tank pumps aren't practical. Mine has given me zero problems.
