Dim right front parking light and turn signal. 1969 Charger
#2379079
09/29/17 10:32 PM
09/29/17 10:32 PM
Posts: 549 WV
JohnH
WV
I've ask this question before,, tried all suggestions,, still dim,, All new wiring harness,, bumper to bumper.. and dash wiring new also,,, the front bulb housing is not new, but excellent shape.. the bulb sockets are perfect shape, switched bulbs.. took housing out,, hooked ground wire to the housing,, unplugged the hood mounted signals, I did everything I could think of.. I worked at a Dodge dealer from 73 to 79.. I was the go to guy for wiring problems,, the only thing I can't think of is a bad turn signal housing.. All the other lights work great... any ideas? When I turn the head lights or the parking lights on, the right green light on the dash lights up.. Thanks,,,
Re: Dim right front parking light and turn signal. 1969 Charger
[Re: JohnH]
#2379083
09/29/17 10:38 PM
09/29/17 10:38 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
check the socket ground inside the housing. sometimes the socket doesn't ground properly where it 'presses/attaches' to the housing. Stick a screwdriver in the crack/seam to jam it, and make a better ground. also make sure the bulb's contacts are touching the contacts in the socket properly as one of the contacts can be worn, and one filament can be grounding thru the other filament.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: JohnH]
#2379094
09/29/17 10:56 PM
09/29/17 10:56 PM
amxautox
Ya, I had a housing problem with the Ramcharger. I put a small screw in that seam and all is still well.
Tom
author unknown
[Re: amxautox]
#2379141
09/30/17 12:43 AM
09/30/17 12:43 AM
Posts: 1,822 Colorado
denfireguy
Colorado
The grounds are notorious for doing this. You can double check it with a long wire from the socket shell to ground. I had to solder a wire to the outside shell and run it separately to ground to fix the one on the Cuda. Did not want to mess with the brand new harness. Wish someone would repop these signal lamp sockets and wires. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: JohnH]
#2379210
09/30/17 10:24 AM
09/30/17 10:24 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Socket is loosen from housing itself. It could be even spinning into housing. Smash the socket lips against the housing to get it tight again.
[Re: cbusters]
#2379737
10/01/17 03:40 AM
10/01/17 03:40 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
As a test, do a temp swap of lamp assemblies from side to side. If the problem moves also, you have your answer. ^^^^This. You can also get three wires and make jumpers and connect them directly from the harness and a chassis ground right to the bulb. If it's still dim on that side, put a volt meter on the circuit and see what you're getting compared to the opposite side. If it's not that housing it is likely at the bulkhead the steering column connector or the blinker switch.
I’m listening.
[Re: JohnH]
#2380457
10/02/17 10:33 AM
10/02/17 10:33 AM
Posts: 1,322 Michigan
crlush
[Re: JohnH]
#2389784
10/19/17 12:47 PM
10/19/17 12:47 PM
Posts: 74 California, United States and ...
Dibbons
I am working on that same problem myself on a 1972 Plymouth Satellite Sebring Plus. The right front turn signal/parking lamp is causing the little green light indicator on the dash to light up when the headlamps or parking lamps are turned on. I removed the right front light module and used a Dremel tool to polish off body paint, polish threads of the screws, and remove oxidation from the pot metal.
Put everything back together and the dash lite was not coming on any longer. However, the front turn signals began doing something weird, they would take turns flashing when I used the emergency flasher. When the left signal went out, the right signal went on, etc. Never did that before, that I know of.
The next day I went to get some gasoline, and the green light (for the right turn signal) on the dash came on AGAIN, when the headlights/parking lights were on.
I will continue to work on the problem. Did not try a second ground wire yet because I thought my cleaning session had taken care of the problem. Bye the way, my stop lights don't work anymore either.
AND for a long time the right tail lamp has "seemed" dimmer than the left tail lamp. But with the tail lamps, it almost seems like the right and left lens are a different shade of red, as if they weathered differently or as if one were newer than the other (don't have any history for the tail light lens).
