Re: Clutch
[Re: Sinitro]
#2386240
10/12/17 12:46 PM
10/12/17 12:46 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
If U want a Borg & Beck 3 finger setup from McLeod, U will need to look around they discontinued this several months back. Though I think some stock may still exist @ Brewers or Passon... Just my $0.02... They discontinued the pressure plate last year. Know one has them in stock. Believe me , I've called around. You can send the pressure plate to Mcleod and they will rebuild it for you.
Re: Clutch
[Re: dogdays]
#2386594
10/12/17 11:21 PM
10/12/17 11:21 PM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
He said it's a McLeod.
OP: You're running a 12" clutch? You will never be able to use up that clutch. Keep it. IIRC there weren't any passenger cars built with 12" clutches. It's a truck piece. (Now watch someone prove me wrong on this!)
The Borg&Beck 11" and 12", plus the diaphragm 11" and 12" use the same flywheelbolt pattern. That's how I put the 12" clutch into my D100 instead of the stock 11".
The only problem with a 12" clutch disk is that it makes the synchronizers work harder. The 12" disk has more rotating inertia and so it's harder to slow it down or speed it up during the shifts.
But in the end, I think you should keep the $$$ and use it for something more important, like chrome valve covers!
The 11" would be better in that respect. You wouldn't even have to change the pressure plate. R. Mcleod sells a 11.95" B&B setup that fits an 11" flywheel, much like the 10.95 "scalloped" setup that Chrysler used.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Clutch
[Re: TOMRR]
#2390533
10/20/17 10:18 PM
10/20/17 10:18 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
TOMRR, The type of set up you need depends on the application. Bigger is not always better. Disc material has came along ways from the old stock rag type which works well in stock applications. Kevlar / rag combination give better performance for some spirited driving. Kevlar/Kevlar disc has the grip that is some times hard to control chatter but will grab and last forever without wearing your pressure plate or flywheel surface. Then there's ceramic. It will hold the most torque but will wear the flywheel out like a grinder. Now multi disc set ups are another topic for people with more money than I have. I get my clutch stuff from AMERICAN POWERTRAIN. They can build you anything you want.
Re: Clutch
[Re: rowin4]
#2390704
10/21/17 09:36 AM
10/21/17 09:36 AM
Posts: 1,014 LEE, MASS
TOMRR
LEE, MASS
TOMRR, The type of set up you need depends on the application. Bigger is not always better. Disc material has came along ways from the old stock rag type which works well in stock applications. Kevlar / rag combination give better performance for some spirited driving. Kevlar/Kevlar disc has the grip that is some times hard to control chatter but will grab and last forever without wearing your pressure plate or flywheel surface. Then there's ceramic. It will hold the most torque but will wear the flywheel out like a grinder. Now multi disc set ups are another topic for people with more money than I have. I get my clutch stuff from AMERICAN POWERTRAIN. They can build you anything you want. Clutch Pkg This is what I ended up getting from Passion Performance in PA. 3-FINGER TYPE PRESSURE PLATE McLeod Clutch Package 12" 23 Spline (Use With 143 Tooth Flywheel) Includes Disc, Pressure Plate, Throw-out Bearing and Pressure Plate Bolts Product Details... I Agree, I have run this same set in my 69RR BEFORE ( All Street Driven) and have had no issues, The only reason I am changing it now I had some engine problem ( Had To Pull Motor)s and thought well it is apart seem like a good idea. Have to work on my back and the less I have to pull the 833 4-speed the better.
