I have been saddled with the un-envionable task of working on a Dodge truck thats been converted to a Delco 21SI Alternator.
The original alternator went bad and the new one only slightly charges. I am thinking there is something wrong with the remote sense wiring.
I have looked on the net and really cant find how this alternator is supposed to be wired. I got a sneaky suspicion that it was installed incorrectly and subsequently ruined the alternator.
Alternator has:
BAT connection
Ground cable
2 wire typical GM plug ( I am assuming this is the sense wiring)
And a small purple wire mounted on stud between the BAT and the two wire plug. ( I am assuming this is the excite wire)
HOW can I jump this into full field mode?
Anyone help with where the wires should lead to? THe bat is obvious, but the 2 wire plug and the purple wire have me at a bit of a loss.
Shouldve told him to just run the self excited 21SI one wire alternator andbe done with it.
