Can anyone help identify these?? #238562
02/28/09 12:04 AM
02/28/09 12:04 AM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
I have some of these pistons i got with some parts i bought and i cant figure out what there are but id like to use them if i could. The only number on the says 437rb ???
www.sikosracing.net Heads up Drag racing
Re: Can anyone help identify these?? [Re: moparmattkos] #238563
02/28/09 12:09 AM
02/28/09 12:09 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Your methods leave something to be desired for measuring piston diameter, lol, but I would guess its a 4 3/8 bore 451 with a 383 rod length for a lo-deck.
8.30's @3400 lbs
Re: Can anyone help identify these?? [Re: Mike Swann] #238564
02/28/09 12:34 AM
02/28/09 12:34 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I know, I know! They're pistons
Re: Can anyone help identify these?? [Re: moparmattkos] #238565
02/28/09 12:54 AM
02/28/09 12:54 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
http://store.summitracing.com/partdetail.asp?part=ROS%2D81762&autoview=sku
do they have 81762 on the quench part of the piston?
also found this on a search at google. Couldnt find it our sale section though
moparts: Engine Parts For Sale - Big Block - FebThey come with file fit rings( .020 top, .016 bottom) They have maybe 1000 miles on them. They have 81762 on the top of the piston and 437rb on the bottom ...
board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5007930&Main=4988487
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Can anyone help identify these?? [Re: kilroy] #238566
02/28/09 01:02 AM
02/28/09 01:02 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
They are Ross pistons.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Can anyone help identify these?? [Re: kilroy] #238567
02/28/09 01:04 AM
02/28/09 01:04 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
The pistons you found are 4.360 dome ross pistons, 3.75 stroke. I know because I was kicking around buying them and the seller sold them. Hence the reason you cant find the ad.
Re: Can anyone help identify these?? [Re: Von] #238568
02/28/09 01:49 AM
02/28/09 01:49 AM
Illinois
mopar addict
mopar addict
Illinois
Are they for a low deck or a tall deck???
Re: Can anyone help identify these?? [Re: moparmattkos] #238569
02/28/09 01:59 AM
02/28/09 01:59 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
They look like Ross pistons to me! With the RB cast into them its a sure bet that they are not for a low deck. mike
Re: Can anyone help identify these?? [Re: kilroy] #238570
02/28/09 09:16 AM
02/28/09 09:16 AM
Illinois
mopar addict
mopar addict
Illinois
They dont have any visable numbers on the quench of the piston.
Re: Can anyone help identify these?? [Re: Sport440] #238571
02/28/09 12:35 PM
02/28/09 12:35 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
FWIW, My 470 lowdeck pistons have RB cast into them also?
Re: Can anyone help identify these?? [Re: Von] #238572
02/28/09 12:43 PM
02/28/09 12:43 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
They sure have Ross machining characteristics but, it looks like
their forging supplier ran out of that particular (Ross) blank
since the name has been machined away inside.
Re: Can anyone help identify these?? [Re: moparmattkos] #238573
02/28/09 01:43 PM
02/28/09 01:43 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Easy, that's a Stanley 25ft Tape Measure
Re: Can anyone help identify these?? [Re: Von] #238574
02/28/09 01:52 PM
02/28/09 01:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well, I guess Im wrong about that then. And I said it was a sure bet. mike
Re: Can anyone help identify these?? [Re: moparmattkos] #238575
02/28/09 01:59 PM
02/28/09 01:59 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
They are definetley Ross pistons. They were custom made in the Ross factory for most likely Probe Industries. I have had a bunch of customs made through Probe and the BB Mopar pistons allways had the Ross machined off. They did forget once and I got them with Ross not machined off. As far as what they fit, a micrometer or at least dig. caliper could measure bore size and comp height. They look like they came out of a motor that had a bunch of debree from spun bearing or a flattened camshaft. My
Re: Can anyone help identify these?? [Re: qwkmopardan] #238576
02/28/09 07:39 PM
02/28/09 07:39 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Yeah you will have to measure the compression height from the middle of the pin to piston deck to get an Idea of what length rod and stroke they were used for. here are a few pics of my Ross 4.375 x 4.375 bore and stroke pistons that use a 7.1" rod.
Re: Can anyone help identify these?? [Re: moparmanjames] #238577
02/28/09 07:40 PM
02/28/09 07:40 PM
Las Vegas NV
Las Vegas NV
another
Re: Can anyone help identify these?? [Re: moparmanjames] #238578
02/28/09 07:42 PM
02/28/09 07:42 PM
Las Vegas NV
Las Vegas NV
last one
Re: Can anyone help identify these?? [Re: moparmanjames] #238579
02/28/09 08:44 PM
02/28/09 08:44 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
They would make good ash trays from the looks of them.
Re: Can anyone help identify these?? [Re: B G Racing] #238580
02/28/09 10:00 PM
02/28/09 10:00 PM
Illinois
mopar addict
mopar addict
Illinois
The rest of them are really nice just this one has a few boogers on it. If i can figure out what they are i was gonna order a replacement piston for this one.
Re: Can anyone help identify these?? [Re: moparmattkos] #238581
03/01/09 09:13 PM
03/01/09 09:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you spent the money on those pistons but you don't have a set of cailpers and a CALCULATOR ??? would take 10 minutes to figure out what they are with those 2 tools and a
