Can anyone help identify these??
#238562
02/28/09 12:04 AM
02/28/09 12:04 AM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
Re: Can anyone help identify these??
[Re: moparmattkos]
#238563
02/28/09 12:09 AM
02/28/09 12:09 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Your methods leave something to be desired for measuring piston diameter, lol, but I would guess its a 4 3/8 bore 451 with a 383 rod length for a lo-deck.
8.30's @3400 lbs
[Re: moparmattkos]
#238565
02/28/09 12:54 AM
02/28/09 12:54 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
http://store.summitracing.com/partdetail.asp?part=ROS%2D81762&autoview=skudo they have 81762 on the quench part of the piston? also found this on a search at google. Couldnt find it our sale section though moparts: Engine Parts For Sale - Big Block - FebThey come with file fit rings( .020 top, .016 bottom) They have maybe 1000 miles on them. They have 81762 on the top of the piston and 437rb on the bottom ... board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5007930&Main=4988487
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#238566
02/28/09 01:02 AM
02/28/09 01:02 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: kilroy]
#238567
02/28/09 01:04 AM
02/28/09 01:04 AM
Von
NE Oklahoma
The pistons you found are 4.360 dome ross pistons, 3.75 stroke. I know because I was kicking around buying them and the seller sold them. Hence the reason you cant find the ad.
[Re: kilroy]
#238570
02/28/09 09:16 AM
02/28/09 09:16 AM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
They dont have any visable numbers on the quench of the piston.
[Re: Sport440]
#238571
02/28/09 12:35 PM
02/28/09 12:35 PM
Von
NE Oklahoma
With the RB cast into them its a sure bet that they are not for a low deck. mike
FWIW, My 470 lowdeck pistons have RB cast into them also?
[Re: Von]
#238572
02/28/09 12:43 PM
02/28/09 12:43 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
They sure have Ross machining characteristics but, it looks like their forging supplier ran out of that particular (Ross) blank since the name has been machined away inside.
[Re: Von]
#238574
02/28/09 01:52 PM
02/28/09 01:52 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Well, I guess Im wrong about that then. And I said it was a sure bet. mike
[Re: B G Racing]
#238580
02/28/09 10:00 PM
02/28/09 10:00 PM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
They would make good ash trays from the looks of them.
The rest of them are really nice just this one has a few boogers on it. If i can figure out what they are i was gonna order a replacement piston for this one.
[Re: moparmattkos]
#238581
03/01/09 09:13 PM
03/01/09 09:13 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
you spent the money on those pistons but you don't have a set of cailpers and a CALCULATOR ??? would take 10 minutes to figure out what they are with those 2 tools and a
