Page 3 of 4 1 2 3 4
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: dustergirl340] #2384397
10/09/17 12:46 PM
10/09/17 12:46 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Originally Posted By dustergirl340
its' a '64. I was actually looking for a '60 valiant and this turned up. It kinda spoke to us whistling ...buy me, buy me... I think the engine swap and exhaust will be slightly easier on this one.
'64 Dart is (almost) as cool as a '65 Dart. Sounds like a fun project. It's for your wife?
This should be a lot of fun because I'll do things weld sawzall to this one I wouldn't do to the challenger.
We're calling it "her car" because she's the one that spotted it. If things work out right this will be the race car and the chally will be more street...work.. or maybe I'll have to get a stacker.
nothing is as cool as a 65 Dart up can't wait to see the paint, have you picked a color yet? green
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384744
10/09/17 09:52 PM
10/09/17 09:52 PM
Parts unknown
590 Challenger Offline
Parts unknown
4.15 Billet Crank, GRP rods, new blower for another 20 lbs of boost to make some real thunder
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384816
10/09/17 11:45 PM
10/09/17 11:45 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I'm going to replace my stock gas tank with a fuel cell so I can better manage my weight due to fuel volume (for NSS indexes).
1979 AMC Spirit, NHRA Q/SA
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384832
10/10/17 12:16 AM
10/10/17 12:16 AM
Fort Collins, Colorado
CoDart Offline
CoDart  Offline
Just got this little 440 huffing some air so my winter plans are porting the heads, arp head studs and a turbo camshaft. Last but not least some drag radials for it to hook up.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384922
10/10/17 03:29 AM
10/10/17 03:29 AM
gregsdart Offline
gregsdart  Offline
Working on getting my other 65 Dart running with the 408 I just built for it. 504 hp on the engine dyno, 904, 4000 +stall converter, 3.55 gears, frame connectors, coil over/rack and pinion front end. Plan on M/T drag radicals, not sure what to expect for ET and mph?
https://vault.myvzw.com/webcs/app/share/invite/HSTxFoiutR
AB6hycxtKkfhW-6f0SA6W_5ni-M5ltcN_Sll--goUa2xiJp90eDJKHk6baRD-TI4PqIZbspLVficQM65EgABaS5P6MVWx2OBrl5tzxjLri1RBAh17iSSzIDn8hzA1_6cDA--.jpg
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384934
10/10/17 08:15 AM
10/10/17 08:15 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
having bought another car at the start of our winter, i had something new to explore & pull apart. The car had been running a blown Hemi on alcohol but i'm making the car an 8 sec bracket car. So, i removed 5 miles worth of uneeded wiring, raised the drivers seat & steering column, fixed the geometry of the steering shaft while at it. made a mount to suit a 727, made a new radiator mount, cut the fuel cell down to 1/3 of its size, removed all the decals, checked the driveline angle, made some headers, stripped out the windows so the car is ready for paint, changed the colour of the cage on the inside &relocated the guages from the steering colun & put them into a blank fiberglass dash. And i made a new rear wing coz i didn't like the other one.
my old car is getting new Larry Smith ported -1's. a new cam & new HS rocker arms. my race season starts in 3 weeks.
20170903_103037 (2).jpg20170903_100045 (2).jpg20170903_100008.jpg20170903_095943 (2).jpg
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384963
10/10/17 10:23 AM
10/10/17 10:23 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^Interesting looking E-body there^^^ smoke
My plans are to change the carpet to black and install some of those carbon fiber roll bar protectors .
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384964
10/10/17 10:23 AM
10/10/17 10:23 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Like to get the RPM's on my car sold and some other stuff so I can upgrade the heads on the car now.
Whole lot of 11.0's and 11-teens I'd like to turn into 10.80's and 10.90's
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384974
10/10/17 10:48 AM
10/10/17 10:48 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
350 passes on my basically stock 727 running low 9's @ 3350lbs. I think I'll take a look. Time to check valve springs, bearings, and add a new pair of slicks.
Doug
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2384992
10/10/17 11:26 AM
10/10/17 11:26 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Swapping the rear drums to strange discs
Changing the gear in the dana from 4.56 to 4.10
Go through the transmission
Building an aluminum block based motor for NSS to step up a little. I will leave the current motor in place until the new bullet is ready. I may start the season on this one.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: Mr340] #2385143
10/10/17 04:04 PM
10/10/17 04:04 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Sawzalls are fun on a car. LOL. And definitely get a stacker!
The Dart will probably be some shade of green (to no one's surprise), though not high impact. Something to fit the mid 60's era.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: dvw] #2385242
10/10/17 07:41 PM
10/10/17 07:41 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Doug
Basically stock?! Haha I've seen the inside of that thing... lol
Well we were hoping to just change out oil pans, add a diaper, and freshen the trans....
However, after last weekend looks like we will now throw a set of gears in it, new driveshaft, freshen the trans, perhaps a new sprague, maybe some axles, and a spool...
Gotta love racing!!!
Casey
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: Whompin_Wedge] #2385379
10/10/17 11:57 PM
10/10/17 11:57 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Doug
Casey
Yea that sucks but better it happened at the end of the year and not the beginning. All that new found power will make any weak links show up. I have a set of 5.88 gears if you are interested. I may try them in mine whistling
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: max_maniac] #2385805
10/11/17 06:43 PM
10/11/17 06:43 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Hmmmmm Winter upgrades. The small block in my black Duster will be getting the solid lift cam pulled and replaced with a bigger roller cam. I will also be doing some more porting and flow testing on my 360-1 heads and I may add a few more cubic inches. My 572 for the small tire car has been on the engine stand forever and I may have it done and going into the car by next week. I would LOVE to make a pass or two NA in November before the local tracks close. Another 408 Edelbrock headed build will be started so Matt and I have a fresh bullet sitting on a stand just in case it is needed. I should also have my 512 Mega block done by March with a very nice set of 440-1 Indy heads. The block is ready to go and the assembly is balanced and ready for installation. Matt also wants to switch his car over to a 9 inch rearend and powerglide so I have 3 powerglides that I will be assembling. Hopefully I have 1 or 2 surprises that I may do but that depends on if I can come up with the needed funds. It should be a busy Winter.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: slantzilla] #2385824
10/11/17 07:23 PM
10/11/17 07:23 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Originally Posted By slantzilla
Originally Posted By B3422W5
Got any pictures of her. What has it run before?
I LIKE IT!
Old Geezer Racing
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2385827
10/11/17 07:26 PM
10/11/17 07:26 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
The plans are to pull this 40 year old 440 out of my 70 Challenger and replace it or rebuild it with newer parts that don't sound like a diesel with piston slap when it is cold. Maybe some aluminum heads and put a real 4 833 4 speed in it instead of the 6 cylinder OD trans that came out of a 80 dodge 6 cylinder.
Then go to the track where I have not gotten to make a run in 36 years. Not since my son was a year old and we needed family money.
Old Geezer Racing
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2385838
10/11/17 07:51 PM
10/11/17 07:51 PM
AndyF Offline
AndyF  Offline
I'll work all winter on both the '65 and the Duster. My project list is too long to write down. I just get up every day and try to accomplish a few things. The shop is heated so I can work all winter in regular street clothes. Not like the old days when I froze solid trying to turn wrenches in the winter.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2385883
10/11/17 09:00 PM
10/11/17 09:00 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
1) Rebuild the 10 year old 670 Street Avenger and get it running right again. The 750 Street Demon I bought is so rich I may as well just run long hose from the local gas pump straight into my intake manifold.
2) Upgrade to a modern ignition system. Probably a Pertronix dizzy, coil, and wires. Realizing that MP orange box conversion on my car is about 25 years old now, and was about 20 year old technology when I installed it.
3) Full suspension rebuild front and rear. When I cruise around the crappy roads in the neighborhood it sounds like someone rolling a 50 gallon drum full of bricks down the road. Sooo many clunks and bangs.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2385888
10/11/17 09:13 PM
10/11/17 09:13 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm stripping, sanding, filling, priming, etc. I now have a special wardrobe just for the above. smile
Fastest 300
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: max_maniac] #2385897
10/11/17 09:23 PM
10/11/17 09:23 PM
COLUMBUS, OH
W
W
COLUMBUS, OH
Doug
Casey
Finally going to go 1/8th mile racing?! haha
Casey
Page 3 of 4 1 2 3 4
