Painting Polyglas GT Letters???? #238476
02/27/09 11:09 PM
02/27/09 11:09 PM
hemibuzz Offline OP
hemibuzz  Offline OP
I have a nice set of orig goodyear polyglas gts.
Anyone had any success freshening up the white
letters? Ive used tire marking crayons, they
are marginal at best. Any ideas??
Re: Painting Polyglas GT Letters???? [Re: hemibuzz] #238477
02/27/09 11:14 PM
02/27/09 11:14 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Have you tried Wesley's Whitewall Cleaner,Comet or got to a local tire shop and buy some liquid rubber buffer.It is used to clean an area for patching and works great to take of black scuff,top layer of dis-colored white on the letters.Good luck
Re: Painting Polyglas GT Letters???? [Re: 44D6PAKCUDA] #238478
02/27/09 11:20 PM
02/27/09 11:20 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I use this stuff
Re: Painting Polyglas GT Letters???? [Re: hemibuzz] #238479
02/27/09 11:26 PM
02/27/09 11:26 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Use 800 to 1000 grit wet or dry (black face) sandpaper. Cut into 1 inch squares and then fold the small piece over (in half) twice. This will give you about a ¼ square with enough material to hold between your index finger and thumb. Make sure the tire letters are wet. Continue to dip the small piece of sandpaper in water as you work. Sand the letters until all dry rot or discoloration disappears. BE CAREFUL NOT TO HIT THE SURROUNDING/RECESSED RUBBER AREAS! Don’t worry about going to far. The letters are solid white all the way through to the sidewall. Be patient. It is a slow process but it will make the letters look pure white and new again. Don't worry about scratches in the rubber. The old rubber sands away to a perfect smooth finish. They will also stay new looking with proper maintenance.
(Tire covers anyone!!!)
Re: Painting Polyglas GT Letters???? [Re: ECS] #238480
02/27/09 11:36 PM
02/27/09 11:36 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
Tire paint is available on the bag.
Re: Painting Polyglas GT Letters???? [Re: Mopar1] #238481
02/27/09 11:53 PM
02/27/09 11:53 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Tire paint will never make the letters look new or original again. The small cracks (from dry rot) need to be removed or dirt and discoloration will always plague them. Painting over the small dry rot cracks and rubber oxidation would be similar to painting over pitted or deeply scratched metal. It will always be detectible. I have used the sanding process on every NOS tire I have and they look absolutely new when they are complete. I have an NOS tire that I have not detailed yet. I will post a picture of two side by side letters to show the results. One letter will be sanded and the other will be in 40 year old, untouched condition.
Re: Painting Polyglas GT Letters???? [Re: ECS] #238482
02/28/09 08:13 PM
02/28/09 08:13 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
try sos pads
Re: Painting Polyglas GT Letters???? [Re: Day2Runner] #238483
02/28/09 08:44 PM
02/28/09 08:44 PM
SE Pa.
LimeliteAero Offline
SE Pa.
try sos pads
Thanks ECS!!!!!!
THAT is the resolution to this issue........
Re: Painting Polyglas GT Letters???? [Re: hemibuzz] #238484
02/28/09 11:29 PM
02/28/09 11:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Trichlorethelene,.......make sure to use it only on the whites, it will dissolve and smear the black permantly, but freshens the white to NEW condition
Re: Painting Polyglas GT Letters???? [Re: hemibuzz] #238485
03/02/09 10:09 AM
03/02/09 10:09 AM
uk
TiMopar Offline
TiMopar  Offline
uk
Don't know if you have them over there, but 'Brillo' pads work great ( soap filled steel wool )...
Re: Painting Polyglas GT Letters???? [Re: TiMopar] #238486
03/02/09 10:47 AM
03/02/09 10:47 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Not to hijack this thread but can you do the same thing with the big rubber bumpers on a 73-74 E-body. Mine look OK but thought if I could lightly sand them they might look new again.
Re: Painting Polyglas GT Letters???? [Re: burdar] #238487
03/02/09 01:49 PM
03/02/09 01:49 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
I prefer the sanding method because chemical processes do not allow for error. The purpose is to make the white/letters appear to be new AND untouched. If the black sidewall area surrounding the letters becomes damaged, altered or manipulated looking, it ruins the desired appearance.
Below are before and after photos. If the letters have deep cracks or dry rot, you can use 400 grit wet or dry sandpaper to remove the old surface. The finish of the rubber will still look new and smooth, even while using the 400 grit paper. A raised white letter or whitewall tire has a solid white layer of rubber beneath the thin black veneering of rubber that covers the sidewall. The letters are solid white blocks that allows for the old oxidized/cracked surface to be safely removed. After using the sandpaper, the white surface residue can be cleaned off with lacquer thinner. I stretch a piece of cloth over my finger, dip it in the lacquer thinner and wipe across the face of the lettering. It leaves them as white as they were when new. Keep in mind that there is no paint or fake coating that is left on the surface to rub or flake off. The rubber that remains is completely original and should last for years with proper care!
