W2 5249769 oiling #2383422
10/07/17 02:10 PM
10/07/17 02:10 PM
maryland
mhead Offline OP
mhead  Offline OP
maryland
Has anyone drilled these heads so you don't have to oil through the push rods.Is this even possible?
Re: W2 5249769 oiling [Re: mhead] #2383510
10/07/17 06:08 PM
10/07/17 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The W-2s that I know you can oil though
either the standard oiling(through the heads)
OR through the push rods.. mine are the econo
heads and I use to oil via the heads.. I then
changed over to a different set of rockers
and had to oil via the push rods.. either way
works great... I did reduce the push rod oiling
with .030 holes and that can be less if wanted..
what heads are yours.. econo or race
wave
Re: W2 5249769 oiling [Re: mhead] #2383747
10/08/17 09:38 AM
10/08/17 09:38 AM
maryland
mhead Offline OP
mhead  Offline OP
maryland
These are the race heads.I bought them bare from mancini a few years back when they was on sale.There isn't any oil feed holes in them and my current block I was thinking of installing them on is tubed.So I don't think they will work on my block.
Re: W2 5249769 oiling [Re: mhead] #2383768
10/08/17 10:43 AM
10/08/17 10:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you can post a pic I would like to see them
thanks
wave
Re: W2 5249769 oiling [Re: mhead] #2384692
10/09/17 08:25 PM
10/09/17 08:25 PM
maryland
mhead Offline OP
mhead  Offline OP
maryland
I haven't been able to figure out how to post a picture.If you want send me a pm with your email so I can send the pic.thanks
Re: W2 5249769 oiling [Re: mhead] #2385439
10/11/17 02:48 AM
10/11/17 02:48 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You can drill thru the rear of the head, pipe tap it, and intersect with the rear rocker stand hole, and finally file a groove in the stand hole threads, then 2 oil lines to rear of block where oil sender goes.
Re: W2 5249769 oiling [Re: mhead] #2385442
10/11/17 02:53 AM
10/11/17 02:53 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I cant see your heads but there is a boss for the alternator on my set....it lines up nicely with the rocker stand hole. Easy job.
