Question on hydraulic preload
#2383359
10/07/17 12:19 PM
10/07/17 12:19 PM
Posts: 1,318 Ohio
jlatessa
Ohio
Putting our 440 back together after a spun rod bearing, (pig rich idle causing pre-ignition!)
Crank now .010 under rods, new bearings on lower end, new head gaskets.
Started engine to look for leaks and adjust idle and heard a rocker tick. Pulled covers and found # 6 intake rocker (Hughes roller, hydraulic .484 cam) with too much clearance. Adjusters tight and the same amt. of threads showing as the others??
This was the cylinder that spun the bearing so I pulled the rocker shaft to see if the rocker had unusual wear showing, also pulled the lifter out to look for face wear, every thing looked normal, lifter face looked great with good convex still apparent, cam lobe too.
so I proceeded to reset that rocker's preload and now I have questions about lifter pump-up when setting.
Does it matter if lifter is still "solid" when setting preload? Will one full turn of adjuster still be correct as Hughes recommends?
New head gaskets, so maybe some variance there, but why #6 only??
Thanks, Joe
Re: Question on hydraulic preload
[Re: jlatessa]
#2383367
10/07/17 12:37 PM
10/07/17 12:37 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Are you sure the cam lobe is good? I would personally be putting an indicator on it and determining if the lobe is worn.
The way I set the preload is rotating the pushrod till the slightest drag is felt and then go the prescribed turn. I usually do it 2 or 3 times to ensure I get the same result - I look at the position of the allen wrench to determine if the results match. So I don't think it matters if the lifter is pumped up but I have heard others say it does.
[Re: jlatessa]
#2383414
10/07/17 01:50 PM
10/07/17 01:50 PM
RapidRobert
I would open it up again & measure everything to find out where the extra clearance is coming from as said starting with the cam. we gotta answer that first. I think you would need to dissassemble/drain the lifter to free it up to be able to check the preload
[Re: RapidRobert]
#2383420
10/07/17 02:04 PM
10/07/17 02:04 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
I would open it up again & measure everything to find out where the extra clearance is coming from as said starting with the cam. we gotta answer that first. I think you would need to dissassemble/drain the lifter to free it up to be able to check the preload Especially the lifter and cam lobe As far as how much preload I back the adjusters off enough to be able to rock the rocker arm up and down a little and then use one hand to pull on the pushrod up and odwn and slowly adjust the adjuster until there is just barely no up and down movement and spin the pushrod like already mention until it has a tiny bit of resistance and then add from 1/8 to 1/4 turn preload on iron heads, 1/4 to 1/3 turn preload total on aluminum heads cold
[Re: jlatessa]
#2383832
10/08/17 12:41 PM
10/08/17 12:41 PM
Posts: 7,506 Az
Crizila
Az
Thanks, Joe If the lifter face looks good, you don't have a cam problem. Same with the rocker. How's the push rod ends? No, they don't have to be pumped up to adjust them. As said, roll the push rod by hand as you tighten the rocker adjuster screw. You will be able to tell when there is no more clearance. Add your 1 turn ( or what ever you choose ) and your done. Yes, they can bleed down occasionally and can take some run time for them to fill back up and quiet down - even after some period of use.- and especially if the car sits for an extended period of time. My guess - The lifter was partially on the lobe ramp when you went to adjust that one innitially.
Fastest 300
[Re: jlatessa]
#2384046
10/08/17 06:58 PM
10/08/17 06:58 PM
crabman173
crabman173
Different lifter brands require or call for different amounts of preload--most all of the Morel hyd rollers call for 1/4 turn--also some of the more expensive units advertised as being capable of higher RPM ( morel makes some of these) call for specific weights of oil The old "throw 3/4 on them and never take the covers off" is OLD stuff for std hyd flat tappet lifters and will not work on modern hyd rollers so Make Sure what mfg they are and call the tech there to make 100% sure what you need A full turn on many Morels is a big no no and cost you performance and will not allow lifter to function as designed quiet operation is not all it is cracked up to be The hyd rollers are so darn heavy--they limit RPM in many cases Solids for me after decades of hoping the hyd rollers would appear--now that they have and I have run them I am back to flat hyd's or my very favorites for performance applications--a solid
[Re: jlatessa]
#2384323
10/09/17 10:35 AM
10/09/17 10:35 AM
crabman173
crabman173
OK Then many go a full turn but the more you preload the less RPM usually --3/4 is a Plenty and half is what we do in our shop pretty much anything will run
