Electrolysis #238340
02/27/09 09:02 PM
02/27/09 09:02 PM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Yep, fired up the new 493 (oh sweet music) ran like a top. Thanks for all the timing suggestions. Started just like everyone said it would. However, i now have Electrolysis! In my opinion everything is grounded very well. My radiator is not though. Any suggestions?
Also, how long before the electrolysis reaks havoc on the aluminum cylinder heads and radiator?
Re: Electrolysis [Re: Plumcrazyracing] #238341
02/27/09 09:18 PM
02/27/09 09:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Electrolysis [Re: Plumcrazyracing] #238342
02/27/09 09:34 PM
02/27/09 09:34 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
How do you know that
Re: Electrolysis [Re: VernMotor] #238343
02/27/09 09:43 PM
02/27/09 09:43 PM
Central Coast
P
P
Central Coast
Cooling system building pressure with no engine temperature.
Re: Electrolysis [Re: Plumcrazyracing] #238344
02/27/09 10:49 PM
02/27/09 10:49 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
saw the problem begin to develop in my engine. I went to my part store{carquest]. they found me a radiator cap, that fit my car, with a zinc attached to it, it dangled an inch or two in the water. Electrolysis will attack the zinc, and not your engine. when the zinc is starting to get eaten up, simply get another radiator cap. Salt water boats have used this tech for years to prevent the problem. It simply works, and no mess, no fuss.
Re: Electrolysis [Re: J_BODY] #238345
02/27/09 11:10 PM
02/27/09 11:10 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
http://www.flex-a-lite.com/auto/html/anode.html
These are the hot ticket; been used in the marine industry since the beginning of time.
Electrolysis occurs. Copper and Aluminum are especially bad.
Remember the trick with the copper, aluminum and lemon in high school science?
8.30's @3400 lbs
Re: Electrolysis [Re: Mike Swann] #238346
02/28/09 01:56 AM
02/28/09 01:56 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I was told to use catapiler antifreeze since it has something in it just for that. That lots of machines and trucks have that problem so thats what I used.I went ahead and got the premixed one it is red in color.
Re: Electrolysis [Re: 340SIX] #238347
02/28/09 02:35 AM
02/28/09 02:35 AM
I'm certainly no expert, but hot water heaters have a "sacrificial anode" for this purpose, and trucks have chemically treated water filters and other chem additives for the cooling systems. I don't pay attention to trucks anymore, so I don't know if many use aluminum radiators or not
Re: Electrolysis [Re: 340SIX] #238348
02/28/09 02:51 AM
02/28/09 02:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I just use a anode like posted above since we cant
use anti-freeze in racing. I havent had any problems
at all and the radiator looks like new
Re: Electrolysis [Re: MR_P_BODY] #238349
02/28/09 10:13 AM
02/28/09 10:13 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
If it is electrolysis the problem is caused by stray current. If it is galvanic corrosion, that is caused by dissimilar metals. Both situations will eat the aluminum, which is low on the galvanic scale. Both can be treated with an anode. I suspect you have galvanic corrosion, not electrolysis. If you disconnect the battery do you still get the radiator building pressure? What time frame are we talking about to build this pressure? If you still get the phenomena with the battery disconnected you have galvanic corrosion. If you only get the effect with the battery connected you have a current leak somewhere (which I suspect is not the case).
Frequently people use the term electrolysis when they really mean galvanic corrosion. Cavitation and ventilation are frequently misused also, people call ventilation cavitation and they are very different. Boy, am I sounding like a pedantic engineer (which I am).
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Electrolysis [Re: David_in_St_Croi] #238350
02/28/09 12:38 PM
02/28/09 12:38 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Heres a story from a few years ago, that just might help some of the racers here..
Back in the day, I worked for the local Telephone utility company.. I was teamed up with the Company grump.. This guy would complain about anything and everything..
One day we were walking to a resturant for breakfast when we passed a beauty salon that was advertising electrolysis.. I said "Hey Ray, this place is for you.. they can remove that one stray hair thats growing up your butt".
and then the fight began....
Re: Electrolysis [Re: David_in_St_Croi] #238351
02/28/09 12:56 PM
02/28/09 12:56 PM
Central Coast
P
P
Central Coast
David, good point. The pressure occured with the battery system disconnected. Ran the motor to operating temperature on a saturday for about 3-5 minutes. Shut down and disconnected battery system. On sunday the cooling system still had pressure. I bled the air. On Tuesday the system had pressure. Bled again. On Thursday the system was FULL of pressure again. Drained system.
What kind of damage do you think this caused to my aluminum heads?
Re: Electrolysis [Re: David_in_St_Croi] #238352
02/28/09 09:37 PM
02/28/09 09:37 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
Re: Electrolysis [Re: Plumcrazyracing] #238353
03/01/09 07:31 AM
03/01/09 07:31 AM
Hi Plum,
I doubt there has been any serious damage to your heads. A zinc anode on a boat usually lasts a pretty long time and that is submerged in salt water. As it sounds like the problem is caused by the dissimilar metals, which you can not change, I would go with the zinc anode or the coolants mentioned. You could also drain the system and refill using distilled water plus whatever antifreeze, water-wetter additives you desire. Distilled water is pretty much just H2O with no other ions so has less current carrying capacity. I know, it sounds as if I am talking about electrolysis again, but while not caused by an electrical current, galvanic corrosion is still an electrical phenomena. The worse of a conductor the fluid is, the less corrosion.
For fun sometime stick an aluminum nail and a copper nail into a lemon. Lemon juice is acidic, copper and aluminum are far apart on the galvanic scale. Put a voltmeter with one lead on each nail, completing the circuit. With the meter set on the lowest voltage DC setting you will be able to detect a current. Several of these in series will light up a flashlight bulb.
Okay, enough science. Now, go buy an anode and burn rubber.
Re: Electrolysis [Re: David_in_St_Croi] #238354
03/01/09 12:16 PM
03/01/09 12:16 PM
Central Coast
P
P
Central Coast
Thank you. Zinc Anode it is!!
Re: Electrolysis [Re: J_BODY] #238355
03/01/09 01:59 PM
03/01/09 01:59 PM
Central Coast
P
P
Central Coast
I found these online at a company called Electroguard in CA. There are several other companies out there (ie.. east and west coast) I was able to get the brass plug and 4 anodes for under 10 bucks shipped (i have no idea how long they last). Jegs and summit sell these for about 15 bucks each plus their handling fees.
Thanks for all the help.
