Re: Propane for Older Mopars
[Re: QuickDodge]
#2382722
10/05/17 10:42 PM
10/05/17 10:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Get with Hank Hill, he knows everything about propane and propane accessories.
[Re: QuickDodge]
#2382893
10/06/17 11:34 AM
10/06/17 11:34 AM
Posts: 74 Stevensville, ON
Frank Raso
Stevensville, ON
If you found a complete propane system from a GM vehicle, then you should be able to install everything on your truck. Be sure to get EVERYTHING, including the control panel and cables from inside the vehicle. The tank is most expensive part of a conversion and other propane system parts are still available and not expensive. Like shown in the video, an Impco Model 300 mixer is commonly used on dual fuel conversions. With vehicles last equipped with carburetors in the late 1980s, carburetor conversion parts have gradually become obsolete. The challenge with a dual fuel system is getting the timing optimized for running 2 fuels. Dual Curve used to make timing controllers for dual fuel engines but now timing advance processors are only made by AEB ( AEB Wolf-N for noncomputerized ignition systems). You can also switch to a computerized ignition system for better timing control. See Megajolt/E. Before converting your truck, you should make sure that you have a readily available supply of low-cost propane motor fuel (HD5). Often, propane companies offer fixed-price supply contracts and the cheapest price can be locked-in during the summer. Ideally, the price of propane should be much less than 50% of the price of gasoline to have a quick payback on the conversion. If your GM conversion is mono-fuel, it would be very similar to the system to the one I installed on my 78 New Yorker which I later transferred to my 77 Pontiac. See Model 425 Mono-fuel Carburetion.
[Re: QuickDodge]
#2382923
10/06/17 12:43 PM
10/06/17 12:43 PM
RapidRobert
Is it a good plan to convert to propane in a DD mainly for a mileage bennie? (mileage VS cost of the propane/the conversion parts & building a high comp eng to take advantage of it). I will go to the listed sites & read up on it.
[Re: QuickDodge]
#2382930
10/06/17 01:04 PM
10/06/17 01:04 PM
Frank Raso
Stevensville, ON
Propane actually has 107% of the energy of gasoline on a mass-basis (ie, BTU/lb), which is how AFR is calculated. Since it is a less dense liquid than gasoline (68%), a gallon of propane has about 73% of the energy of a gallon of gasoline. You will never get the same mpg fuel efficiency with propane with a carbureted propane system but it's not hard to get 75-80% of your car's gasoline economy on propane. However, the cost of operation should be much lower if you buy low cost propane. In Ontario, the cheapest places to buy propane is where the taxis fill up, which is around Pearson Airport. Since HD-5 propane has an octane number of 104, you can safely run a higher compression ratio (eg 10.5:1) without any risk of knocking. Higher compression ratios increase the fuel efficiency of ANY internal combustion engine. See Fuels Forum: Compression Guide. Mixer-based dual fuel engines will make less power than a mono-fuel engine because of the added flow restriction of the gasoline carburetor. However, both may be tuned to provide the optimum fuel mixture. Someone out in oregon had converted his slant six truck to propane and used the MegaJolt/E ignition system. He found that his truck ran better on propane than gasoline and needed a lot less timing than commonly thought. See Slant Six Forum: My timing map....
[Re: QuickDodge]
#2382953
10/06/17 01:53 PM
10/06/17 01:53 PM
Frank Raso
Stevensville, ON
It's a lot easier to set up a mono-fuel system than a dual-fuel system and you need to make sure that you get the best advance curve for each fuel. Burned valves often indicate excessively rich propane fuel mixtures. Gaseous fuels do not have the evaporative cooling effect that rich mixtures have with gasoline. See Fuels Forum: Combustion Temperature. Good point about old fuel. Gasoline will become stale if not used continuously while propane never becomes stale. Modern injection conversions always start on gasoline, which helps to keep gasoline in the tank fresh.
[Re: 67Satty]
#2382981
10/06/17 03:00 PM
10/06/17 03:00 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
OP, don't waste your money or energy on the conversion I had one of my old car hauler one ton trucks converted back in the mid 1970s when the first gas crisis was occurring for the increased fuel storage, 85 gallon tank. It had a 318 industrial poly motor in it and burnt the valves up real quickly Major expense on installing harden seat and new valves that truck got 8.5 MPG on gas and 7.5 MPG on propane I later bought a M1500 I.H chassis Class A 26 ft. motorhome that was set up on propane only, it sucked on POWER and MILEAGE I removed the system, converted it back to gasoline and never looked back and I never regretted it
[Re: 67Satty]
#2382982
10/06/17 03:02 PM
10/06/17 03:02 PM
dogdays
Go back up the page and read all of Frank Raso's posts. He seems to have the best handle on the issue. You do not get a mpg increase going to propane. The only reason to go to propane is that the fuel costs so little that its miles per dollar comes out ahead. Propane prices vary a lot. My parents had propane for heating house and water. They'd stock up when the price was low. The problem as I see it with dual fuel systems is that an engine optimized for propane is different than an engine optimized for gasoline. One thing that you all have missed is the decrease in air volumetric efficiency while on fully vaporized propane. Gasoline engines run best when the fuel enters the combustion chamber in the form of tiny droplets. The ratio between vaporized gas and liquid gas is about 1000:1. So to get the maximum amount of air into the engine you have to make the fuel take up less space. Propane is vaporized before or in the mixer and as the air/fuel mixture reaches the cylinder the fuel takes up a much larger percentage of the total, limiting air and thus limiting power. BTW, the term "air volumetric efficiency" is something that I just made up. I don't know if there's a real term for this. Here's my wonder....Why do we have to vaporize it before it enters the chamber? IMHO it might prove to be better if injected into the ports directly as a liquid. As it flashes to vapor (-156F) it'd greatly drop the temperature in the intake ports and increase the air volumetric efficiency. Even just a little LPG injected into the intake manifold near the start of the runners would supercool the air, increasing power. I seem to remember that LPG stays liquid at 125psi at room temp. As we now have Diesel engines in trucks running fuel rail pressures of 26,000psi, and the gasoline fuel injectors on cars have proven to be nearly bulletproof, the technology is there to give it a try. Watching Gale Banks' turbocharging video last night, he mentioned that using methanol eliminated the need for an intercooler. How about using the liquid propane in an eductor setup to drag more air into the cylinder? I think that we're ignoring the best uses for propane because it's easiest to just use what has been available for the last 50 years. R. Well, I goofed again. I did a search after I had posted rather than before. Google "liquid propane injection" and you get thousands of hits. Oh, well. Here's a great example: http://www.eng-tips.com/viewthread.cfm?qid=129931
[Re: dogdays]
#2383001
10/06/17 03:23 PM
10/06/17 03:23 PM
DaytonaTurbo
Manitoba, Canada
Liquid propane injection systems like you envision are on the market and available. However the cost of the injectors is so high that most guys looking into propane go back to the old standby Impco mixers after the sticker shock of the liquid injection systems. But yes, you're right in that the gaseous propane fuel is a restriction, in theory, however I have never seen any documentation to find out if this is an actual real-world factor. You can also get gaseous propane injectors that inject the propane gas right at the cylinder ports. Sort of a compromise between the old mixer and the liquid system, with the drawbacks of both. I have read successful stories of blower and turbo guys using propane, I would guess the boost would more than make up for the potential air volume lost by the gaseous propane. For a n/a engine, either a purpose built propane engine where peak hp isn't the goal but cost per mile is, a mixer could work well. Another thought I had is a n/a engine, high compression that runs race gasoline on the strip and propane on the street. Although you would basically need to do propane injection because the dual fuel mixers are all far too restrictive for a high hp single carb engine.
[Re: dogdays]
#2383002
10/06/17 03:24 PM
10/06/17 03:24 PM
Challenger 1
Cincinnati, Ohio
R.
Well, I goofed again. I did a search after I had posted rather than before. Google "liquid propane injection" and you get thousands of hits. Oh, well. Best not to post if your not sure because you are wrong about plenty of stuff here dog More later by me on this subject.
[Re: QuickDodge]
#2383010
10/06/17 03:58 PM
10/06/17 03:58 PM
Frank Raso
Stevensville, ON
While gasoline leaves the carburetor as an atomized liquid, some or all will flash into vapour in the intake manifold, depending upon manifold vacuum and air temperature. As gasoline vapourizes, it cools the fuel mixture and the intake manifold. All OEM intake manifolds have a hot spot in the intake manifold to compensate for this cooling effect. At full throttle, manifold vacuum is low and air flow is high so gasoline can enter the combustion chamber as an atomized liquid rather than vapour. Atomized gasoline displaces very little air. Because engines need as much air as possible in the combustion chamber (ie, volumetric efficiency), this helps the engine to make more power. Propane expands 270 times going from liquid to vapour. I'm not sure how much gasoline expands when it vaporizes. In a gaseous fuel engine, the fuel displaces some of the air entering the combustion chamber so it will produce less power than a gasoline engine. If you're not running your engine at full throttle, you won't notice this effect. On the street, a properly tuned propane engine will be very responsive because it doesn't require an accelerator pump and there will virtually no fuel mixture variation from cylinder to cylinder. A simple performance improver for an Impco propane carburetor is the Impco VPV (Vacuum Power Valve). This device allows the engine to run slightly lean for better fuel economy and then enriches the fuel mixture when vacuum falls below 3"Hg. As for liquid injection, I believe Icom NA has the only system available in North America. I think their focus now is on fleets and I'm not aware of their JTG system for retrofits. If they did, if would only be for EFI engines. Roush had the JTG system on their trucks about 10 years ago. See Roush Propane F150.
[Re: DaytonaTurbo]
#2383033
10/06/17 04:49 PM
10/06/17 04:49 PM
Frank Raso
Stevensville, ON
But yes, you're right in that the gaseous propane fuel is a restriction, in theory, however I have never seen any documentation to find out if this is an actual real-world factor. You can also get gaseous propane injectors that inject the propane gas right at the cylinder ports. Sort of a compromise between the old mixer and the liquid system, with the drawbacks of both. If you're not racing, propane is an excellent fuel for spark-ignition engines. Besides having excellent fuel distribution, its gaseous nature ensures that engines last longer because it doesn't wash oil off from cylinder walls. While gaseous fuels produce less full throttle power because they reduce the engine's volumetric efficiency, the fact that they also reduce volumetric efficiency at part throttle means that the throttle must be opened slightly more, which reduces manifold vacuum. Propane gets a slight fuel efficiency boost by the slight reduction in pumping losses with lower manifold vacuum. One issue with liquid injection is that the fuel is continuously circulated back to the fuel tank. The fuel then picks up heat from the pump, from the engine, and from radiation from hot pavement. If the fuel pump fails, then you need to empty the fuel tank (like an AC system) to fix it. Without a fuel pump, fuel will flow to a propane carburetor down to -40°F. Both vapour and liquid injection systems both need some additional tank pressure (ie, from ambient temperature) in order to run. Propane carburetors also don't need a choke to start in cold weather and will idle smoothly immediately after starting. This is video of my Pontiac starting at 0°F: [video:youtube] https://youtu.be/74CqA71DmRA[/video] A drawback for some is an advantage for others.
