Small block Indy Edelbrock high flow heads
#238122
02/27/09 06:42 PM
02/27/09 06:42 PM
Has anyone out there ran the combination of the small block Indy Edelbrock heads (with the offset rockers) along with a hydraulic roller cam? I'm having major issues with the clearance for the push rods through the heads. The owner of Indy heads told me he never considered the combination and has no idea if it will work.
Re: Small block Indy Edelbrock high flow heads
[Re: 5spdcuda]
#238124
02/27/09 07:11 PM
02/27/09 07:11 PM
The tightest fit is on lower inside portion of the pushrod hole. I don't know if I can even grind off enough aluminun to gain the clearance I need. I don't want to grind the hell out of it and find out it's not going to work anyway. I don't want to get rid of my roller cam if I don't have to. I'm hoping someone else can tell me they've done it and it'll will work.
[Re: RyanJ]
#238126
02/27/09 07:36 PM
02/27/09 07:36 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I have those heads on a 9.350 deck with a solid roller and 3/8 push rods had to do a small amount of work with the die grinder.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: RyanJ]
#238127
02/27/09 07:41 PM
02/27/09 07:41 PM
I'm also concerned about the extreme angle of the pushrod. Small block Mopars have an extreme angle from the factory and then you add the longer lifter and the offset rockers and it's amplified even more. Is this ok also?
#238128
02/27/09 07:42 PM
02/27/09 07:42 PM
dusturbd340W5
Kissimmee Fl.
a w2 motor has more angle than these do should be fine
[Re: 69Cuda340S]
#238131
02/28/09 12:23 PM
02/28/09 12:23 PM
I already ran the engine with the hydraulic roller cam and lifters. I had performer rpm heads and just changed to the Indy Edelbrock heads with the offset rockers and relocated push rod holes. It really looks as if it won't work, but I guess if others have done it it must.
[Re: 69Cuda340S]
#238133
03/01/09 11:20 AM
03/01/09 11:20 AM
This is how far they are off. The pushrod hole is so far off, the tip of the pushrod can not even seat in the lifter and you can see how far off it is to the rocker.
#238134
03/01/09 11:23 AM
03/01/09 11:23 AM
dusturbd340W5
Kissimmee Fl.
WOW I didnt have that problem I am running a 3/8 push rod and they fit but they where rubbing a little didnt take much grinding for them to clear.
[Re: dusturbd340W5]
#238135
03/01/09 11:32 AM
03/01/09 11:32 AM
Did you use these same rockers from Indy? I think I'm missing some spacers between the rockers and the shaft mounting posts. Besides that some of the rollers don't even turn.
[Re: Diablo]
#238137
03/01/09 11:48 AM
03/01/09 11:48 AM
I called Comp Cams, they don't make an offset hydraulic roller lifter. I'd hate to have to get rid of these lifters, I paid $700 and they only have about 1000 miles on them.
#238138
03/01/09 01:48 PM
03/01/09 01:48 PM
dusturbd340W5
Kissimmee Fl.
yes I am running the Indy 1.6 blue rockers
Re: Small block Indy Edelbrock high flow heads *DELETED*
[Re: dusturbd340W5]
#238139
03/01/09 02:21 PM
03/01/09 02:21 PM
Post deleted by Blown Barracuda
#238140
03/01/09 03:26 PM
03/01/09 03:26 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What is the offset on the intake rocker arm. I know the Indybrocks require a different intake rocker arm but the offset on yours look the same (intake and exhaust). Probably just my old eyes.
