Fitech guys, 12v source for white wire??
#2380836
10/02/17 08:59 PM
10/02/17 08:59 PM
Posts: 1,412 E Central IN
nd65
E Central IN
Running factory electronic ignition. Jumped white wire to battery to get it going. What do you suggest as a source for the white wire?
Thanks,
nd65 nd.neal@gmail.com
Re: Fitech guys, 12v source for white wire??
[Re: 540challenger]
#2381185
10/03/17 11:48 AM
10/03/17 11:48 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Maybe if he stayed off the crack he could figure it out
[Re: nd65]
#2381202
10/03/17 12:11 PM
10/03/17 12:11 PM
Supercuda
About to go away
About to go away
up yours
All you need to do is use the run line and the start line, tap them both through a diode and use that for your connection.
It is not rocket science.
Use the diode to prevent back feed from one source to the other.
[Re: nd65]
#2381291
10/03/17 04:18 PM
10/03/17 04:18 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yep, diode is the easiest way.
[Re: nd65]
#2381379
10/03/17 07:52 PM
10/03/17 07:52 PM
Posts: 4,744 Florida
BDW
[Re: BDW]
#2381395
10/03/17 08:25 PM
10/03/17 08:25 PM
nd65
E Central IN
[Re: nd65]
#2382187
10/05/17 12:20 AM
10/05/17 12:20 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Thanks Supercuda,
John, thank you very much for the drawing.
Did a little research on diodes and kind of getting it now. What diode would you recommend I get?
Thanks, nd65 1N4000 series are great for this. (1N4001, 4002, 4003, etc) and you can buy a bunch for a dollar. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: nd65]
#2387280
10/14/17 11:46 AM
10/14/17 11:46 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I get it now!!
Ignition 2 is the start mode and has 12 volts while cranking (brown wire).
Ignition 1 is run mode (blue wire). It has 12 volts when you let off the key when the engine starts.
The diode is basically a check valve. It only allows current to flow 1 way.
The diode gets wired from ignition 2 to ignition 1. This will allow 12 volts from the ignition 2 start (or crank) mode to flow to ignition 1 run mode. When the engine starts and you let off the key the diode (or check valve) prevents the 12 volts from ignition 1 from flowing back to ignition 2. Thus, ignition 1 always has 12 volts and the Fitech is happy. Correct... the Diode keeps working the ballast to the coil in run correctly with the decayed power. there was a nice discussion about this couple of months ago. A relay can be used too allong with diode, but makes a bigger and "complex" installation. Not required if the source needed is mainly just for triggering, and not for sourcing more than the stock system
[Re: nd65]
#2387287
10/14/17 11:56 AM
10/14/17 11:56 AM
NachoRT74
Valencia, España
I'm wondering about the posibility of a modified ballast to hide this diode jumping job, cuting the ceramic on back with a dremmel enlarging the groove and solding to the existant ballast ends on groove... would be an interesting job!
Of course, prongs will need to be labeled to plug Ign 1 and 2 on the same position allways
