Re: 318 distributor swap help
[Re: ChallengerGary]
#2380022
10/01/17 04:26 PM
10/01/17 04:26 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Pretty sure your original unit is a hall effect with no vacuum or centrifugal advance. The parts store unit has both advance mechanisms and a magnetic pickup. It will need a different ignition system retro fitted. It will eliminate the computer spark control system which is probably what you want anyway with the engine change and bolt on's you're using.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2380029
10/01/17 04:29 PM
10/01/17 04:29 PM
Posts: 2,143 Port Saint Lucie, FL
ChallengerGary
Robert OK - so how do I do that?
#2380060
10/01/17 05:27 PM
10/01/17 05:27 PM
Andrewh
search on the partnumber brings up 2 places you might still get it. https://www.jimsautoparts.com/mopar_performance_ignition.htmshows it, but who knows. and http://www.ebay.com/itm/Proform-Electronic-Ignition-Distributor-Kit-Mopar-Dodge-Chrysler-273-318-340-360/253126678466?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D47507%26meid%3Dd37e74565d91471ea38f31aed10b5203%26pid%3D100011%26rk%3D1%26rkt%3D4%26sd%3D331134788435&_trksid=p2047675.c100011.m1850 not mopar parts, but looks like all the pieces. if nothing else Jims might have the other parts you need as they are listed individually.
[Re: 3hundred]
#2380542
10/02/17 01:09 PM
10/02/17 01:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
And? Not a mind reader here.
[Re: Supercuda]
#2380603
10/02/17 02:41 PM
10/02/17 02:41 PM
RapidRobert
I would keep the (new) dist with the vac adv & wire in an ECU/ballast. Schematics are in the archives.
#2380857
10/02/17 09:35 PM
10/02/17 09:35 PM
RapidRobert
& when it is up & running we can dial in the dist subsystems to get the most out of it.
