Head flow #'s #2380783
10/02/17 07:50 PM
10/02/17 07:50 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
I'm not a head guy, but I need to know if these heads are flowing enough for a 10 - 11 sec car.
Specs are as follows:
Intake numbers
.100 78
.200 148
.300 202
.400 249
.500 291
.600 320
Exhaust
.100 66
.200 111
.300 159
.400 192
.500 200
.600 215
Re: Head flow #'s [Re: 70Challengerse] #2380790
10/02/17 07:55 PM
10/02/17 07:55 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Yes! And if the car is light enough and built correctly. Well built engine only.
Re: Head flow #'s [Re: Rob C] #2380797
10/02/17 08:02 PM
10/02/17 08:02 PM
416 stroker , 11.1 cam to be determined, 3000 lb car intake victor jr match flow..
Re: Head flow #'s [Re: Rob C] #2380798
10/02/17 08:05 PM
10/02/17 08:05 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Not enough info but yes if the car is under 4600 pounds
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Head flow #'s [Re: pittsburghracer] #2380807
10/02/17 08:14 PM
10/02/17 08:14 PM
Thanks guys, got the input I need, got a line on new heads and intake, I just want to run low 11's easily , mainly street car. I'll get a combo to make it work..
Re: Head flow #'s [Re: pittsburghracer] #2380822
10/02/17 08:41 PM
10/02/17 08:41 PM
pennsylvania
poboyengineering Offline
pennsylvania
Good one.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Head flow #'s [Re: 70Challengerse] #2380863
10/02/17 09:45 PM
10/02/17 09:45 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I think those numbers are higher than my 915's on my 440 in my Cuda and I ran 10.80's @ 3200 lbs.
[image][/image]
Re: Head flow #'s [Re: sgcuda] #2380907
10/02/17 10:54 PM
10/02/17 10:54 PM
PA.
"Little"John
"Little"John
PA.
I know they flow a lot more than my old 906 heads 27 years ago and I went 9.80 @ 2800 pounds. Its all about the combo.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head flow #'s [Re: sgcuda] #2380924
10/02/17 11:08 PM
10/02/17 11:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The head flow is fine...the weight is fine...
now its just a matter of the conv and the
right gear with the right cam... W-2 heads
flow only about 310 cfm on my 416 and my
Rampage is only a less weight (2900#)
EDIT
What heads are yours... thats a ton of flow
for .600 lift... but you should be low 10s
wave
Re: Head flow #'s [Re: 70Challengerse] #2382721
10/05/17 10:42 PM
10/05/17 10:42 PM
Earth
Rob C Offline
Rob C  Offline
Earth
What heads are these?
Re: Head flow #'s [Re: 70Challengerse] #2382913
10/06/17 12:12 PM
10/06/17 12:12 PM
warren, mich.
dwayne welder Offline
warren, mich.
Just compare to the NHRA stock eliminare cars at INDY in the final!!! Good Luck
