Re: A518 overdrive swap into a 68 D200
[Re: Hemi_Joel]
#2376243
09/25/17 06:47 AM
09/25/17 06:47 AM
Guitar Jones
With the 4.10 gear the 518 will be fine, you don't need the 2.74 first gear in the 500. You may need a later style crossmember or modify yours. The tail shaft housing is wider than the 727. You will need to shorten the drive shaft and you will also need a 3/8" cooler and lines. The 5/16" lines and stock cooler will not provide enough fluid volume to lube the intermediate shaft and O/D unit. I would make sure you get and use a lock up converter. It's worth about 300-400 rpm reduction.
[Re: Hemi_Joel]
#2376416
09/25/17 01:06 PM
09/25/17 01:06 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
This truck has 4.10's and a 318. It's no rocket sled, but it gets around surprising well in stop and go traffic. I bolt from stop lights and leave most cars behind. Not in a race, but it goes quicker than the average commuter chooses to. But it sure is screaming on the freeway at 75. My 2001 Ram1500 Off-Road package truck has factory 4.10 gears and an OD automatic.It has tall 275/7017 tires which is why the 4.10 ratio was used,at 70 mph it is around 2100-2200 rpm.I'm sure your truck is closer to 3000 rpm at that mph or slower even with no OD.It will make your truck bearable at highway speeds for sure! RT
[Re: Hemi_Joel]
#2378108
09/28/17 02:05 AM
09/28/17 02:05 AM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
It will. The weight is just spot welded on so some careful hammer and chisel work solves the problem. Kevin
