Steering shaft lengh-manual A-body #2376565
09/25/17 04:35 PM
09/25/17 04:35 PM
lancaster,california
johnnycuda Offline OP
Hey guys, the steering shaft is my Valiant had got collapsed, I'm pulling it back out, does anyone know the length it is supposed to be?, and from where it smeasured?, ( from end to end or from after the threads etc).
Thanks,
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Steering shaft lengh-manual A-body [Re: johnnycuda] #2376572
09/25/17 04:44 PM
09/25/17 04:44 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
There are a bunch of threads on this in the Q&A section... If memory serves me it's like 43 or 43-1/2 inches overall. Hook a tape inside the hole where the column comes out and measure to the where the coupler will end up on the input shaft on the steering box. Push the bracket up to the stops on the column and measure again from the bracket to the end of the coupler. You should be able to make those two measurements close to equal.
Re: Steering shaft lengh-manual A-body [Re: johnnycuda] #2376587
09/25/17 05:01 PM
09/25/17 05:01 PM
I will look into the Q&A archives, I have the shaft out of the column and it out of the car, reassembling the car after paint. Thought about tacking the shaft at the slip point before installing back into the column.
Re: Steering shaft lengh-manual A-body [Re: johnnycuda] #2376594
09/25/17 05:12 PM
09/25/17 05:12 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I had to lengthen my shaft as well when I went from power to manual in my A-body. I didn't bother tacking it back together because it can't go anywhere once it's bolted in.
Re: Steering shaft lengh-manual A-body [Re: johnnycuda] #2376655
09/25/17 06:55 PM
09/25/17 06:55 PM
Yeah, kinda thought that may not be needed.
