'76 3/4 ton, light versus heavy. #2374584
09/21/17 04:07 PM
09/21/17 04:07 PM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
I have a 76 D-200.
I swapped out the rear axle a number of years ago.
Now the lug nut size is different from front to back.
The rears are the 1/2"-20
The front is the larger 5/8"-18 size.
Can I swap the rotors or must I find a complete spindle set-up?
Ball joints?
Control arms?
I need to know what I'm looking for when I go salvage yard shopping.
The new wheels I bought do not fit over the larger studs up front.
Thanx in advance for any help.
I have mechanical Aptitude.
I can screw up anything.
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2375027
09/22/17 02:00 PM
09/22/17 02:00 PM
Lost and Spaced
Lost and Spaced
Anybody ? shruggy
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2375099
09/22/17 04:31 PM
09/22/17 04:31 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'm pretty sure everything that came with the 5/8" studs was in a class by itself. It should have bigger ball joint studs and bigger tie rod ends, and heavy duty control arms, I'm not sure any of the lighter duty stuff will match up. You are likely going to need to change everything from the frame out on both sides as well as the tie rods, maybe even the steering link attached to the steering box.
I'm pretty sure the frame brackets the control arms bolt to are the same as the lighter stuff, and I believe the steering box itself is the same, but I never really got into swapping out the 5/8" stud stuff when I found out the ball joints and tie rods were not interchangeable. It wasn't worth the cost of the change over to me at the time. Gene
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2375291
09/23/17 12:40 AM
09/23/17 12:40 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
My W300 has 5/8" studs. Not sure about the 3/4 ton trucks?
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: '76 3/4 ton, light versus heavy. [Re: 19swinger70] #2375322
09/23/17 02:18 AM
09/23/17 02:18 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Never seen anything but 1/2" on a 3/4 ton truck......
Ed
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2375360
09/23/17 09:19 AM
09/23/17 09:19 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Bboogieart, can you post pics of the front suspension?
Sounds like your truck might have come with the 4000# front end. If it did, you can probably just swap the wheel studs for ones from a 92 D250 Cummins, those used the 4000# front end and have 1/2" studs.
Poorboy is right about not mixing and matching ld and hd stuff.
Are your front rotors a separate rotor and hub or all 1 piece cast? I don't think the 2 piece were used on anything but the 4000# axle.
Angry white pureblood male
Re: '76 3/4 ton, light versus heavy. [Re: ruderunner] #2375494
09/23/17 02:41 PM
09/23/17 02:41 PM
Lost and Spaced
Lost and Spaced
I changed the rear axle years ago, for an '84 unit.whistling
The rotors appear to be two piece.
I too, don't feel like changing out the entire front end.
"maybe swap the wheel studs for ones from a 92 D250 Cummins".
I like this idea. Will look into it, and report back.
Sure would simplify things if it works.
If not, well, we'll cross that bridge.
The truck only gets used to go to the dump or salvage yard.
Any other hauling I use the van.
Again, thanks for all the input and help. up
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2375537
09/23/17 04:02 PM
09/23/17 04:02 PM
Lost and Spaced
Lost and Spaced
They most definitely made a heavy and a lite 3/4 ton.
It looks to be the 4000# axle.
The '84 looks to have been the lighter duty truck.
Truck weighs 4600#s empty but with me in it,
going over the scale at the scrap yard.
I thought about drilling the holes in the wheel.
Then I thought better of it.
I see someone else has thought the same thing and was advised against it.
Again, Thanks for all that responded. up
More pictures for clarity.
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2375769
09/24/17 01:10 AM
09/24/17 01:10 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
i am thinking there are special studs made to neck down the big 5/8 holes to the 1/2 inch studs----seems i was doing axles on a 1 ton srw cummins 89-90 and front to back were different because of a previous swap---i found some on a couple loose hubs and made it work....
Re: '76 3/4 ton, light versus heavy. [Re: savoy64] #2375772
09/24/17 01:18 AM
09/24/17 01:18 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Learn something new everyday.....never seen a setup like that on a 2wd truck.
Uses the same brake calipers as a dana 60 4x4 truck.
What is the gvw on the truck?
Ed
Re: '76 3/4 ton, light versus heavy. [Re: Mr. Smurf] #2375793
09/24/17 02:46 AM
09/24/17 02:46 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The heavy ones are called "9500"s and have bigger wheel studs. I had a 78 like that.
Sheldon
Re: '76 3/4 ton, light versus heavy. [Re: ruderunner] #2375861
09/24/17 12:18 PM
09/24/17 12:18 PM
Lost and Spaced
Lost and Spaced
Originally Posted By ruderunner
Byou can probably just swap the wheel studs for ones from a 92 D250 Cummins, those used the 4000# front end and have 1/2" studs.
Do I just swap the studs or can I swap the disc?
Re: '76 3/4 ton, light versus heavy. [Re: Mr. Smurf] #2375875
09/24/17 12:42 PM
09/24/17 12:42 PM
Lost and Spaced
Lost and Spaced
I learned something today. up
Looking to learn more.
That is most likely what the rear axle was I swapped out.
The replacement came from an '84 3/4 ton pick up truck.
At the time I never even thought to look at the studs.
I had it, I used it.
Tag says;
Front-3400
Rear-6200
Total-9000
Truck weighs 4400#s
It's says D-200 on the front fender.
Title just says Year-1976, MAKE-DODGE, VEHICLE TYPE-TRUK
shruggy
Re: '76 3/4 ton, light versus heavy. [Re: RUNCHARGER] #2375878
09/24/17 12:55 PM
09/24/17 12:55 PM
Lost and Spaced
Lost and Spaced
Are you talking pick-up,
or the Tow-truck/Dump-truck/Flat-bed sized units?
Those were more than one ton or bigger, were they not?
Those would be even bigger studs yet.
I thought the 70's pick-up trucks were all
D or W 100
D or W 200
D or W 300
I've got a 78, but it says 150 on it.
It's Prospector/Adventurer in a half ton.
I'm pretty sure this is simply the heavy 3/4 ton.
The smaller version was simply a light 3/4.
Both D-200 designation.
Am I wrong in this assumption?
Re: '76 3/4 ton, light versus heavy. [Re: Mr. Smurf] #2375883
09/24/17 01:02 PM
09/24/17 01:02 PM
Lost and Spaced
Lost and Spaced
Was the 300 a 4 wheel drive, 1 ton truck?
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2375936
09/24/17 02:59 PM
09/24/17 02:59 PM
ohio
ohio
Think you should be able to swap studs. Not sure the whole hub and rotor combo swaps.
As for model designation,. D is 2wd,. W is 4wd. 100 is light half ton, 150 is heavy half, these came about in the mid 70's due to emission regs. 200 is 3/4 and 300 is 1ton.
The 9500 tossed out above is referring to gvw.
Re: '76 3/4 ton, light versus heavy. [Re: ruderunner] #2375947
09/24/17 03:24 PM
09/24/17 03:24 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Yes: The 9500 was a heavy GVW package that came optional on a D200 and probably a W200. It upped the GVW of what the truck could haul and of course it included lots of HD suspension components. They generally had an emblem on the exterior denoting the package. They came about due to the heavy campers of the day being too heavy for a D200 to carry.
Sheldon
Re: '76 3/4 ton, light versus heavy. [Re: RUNCHARGER] #2376034
09/24/17 07:43 PM
09/24/17 07:43 PM
Lost and Spaced
Lost and Spaced
I knew the W versus D thing.
Mine is 9000# GVW.
I suppose that puts it in the heavy weight class?
I have heard of lite and heavy 3/4.
Lite and heavy half ton is news to me.
I thought the 150 thing was an '80's designation for half ton.
We live- we learn.
Anyway, it seems I'm looking for the '90's Cummins parts, or possibly some replacement studs.
We'll see how it goes.
I'll get back when I have some news.
Thanks again.
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2376195
09/25/17 01:20 AM
09/25/17 01:20 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I had a 73 D200 "Camper Special" Club cab. It came with a 400, 727 and the HD suspension with the 5/8" studs. I also had a 75 D200 Camper Special that came with 5/8" studs, that one was a 318 727 standard cab truck. The 78 Camper Special had 1/2" studs.
I believe it really depended on what box was checked on the truck order blank.
I've been involved with the D/W 100, 150, 200, 250, and 300 debate before. I'm not going there again. Gene
Re: '76 3/4 ton, light versus heavy. [Re: poorboy] #2376360
09/25/17 12:05 PM
09/25/17 12:05 PM
Lost and Spaced
Lost and Spaced
Yeah Gene,
I get the check box, order sheet, deal.
Likely the best explanation.
As for the debate?
I'm not here for that either.
Planning on going to the parts counter today
to see what we can come up with.
After that it will be the salvage yard.
Worst case scenario would be to buy more new wheels.
Some how or the other those 16.5's gotta go.
That old beater has a lot of life in it yet.
