E body pedal assembly, I would like to convert to power brak #2375536
09/23/17 03:56 PM
09/23/17 03:56 PM
San Diego
formula S Offline OP
San Diego
I have a 73 barracuda with a manual transmission and manual brakes, is there any difference in my pedal assembly than what they used in a power brake car
Re: E body pedal assembly, I would like to convert to power brak [Re: formula S] #2375572
09/23/17 05:44 PM
09/23/17 05:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
There is a bell crank that goes between the pedal and the booster.
Re: E body pedal assembly, I would like to convert to power brak [Re: formula S] #2375592
09/23/17 06:24 PM
09/23/17 06:24 PM
OT from what I understand they both have the same brakeing force just that PB require less leg to apply that force & they do give less actual feel. Is there an issue with the manual brakes right now? we might be able to solve it.
Re: E body pedal assembly, I would like to convert to power brak [Re: RapidRobert] #2375614
09/23/17 07:24 PM
09/23/17 07:24 PM
IN
ahy Offline
ahy  Offline
IN
If you cannot find original linkage parts, a kit like the attached would do it.
https://www.mpbrakes.com/images/MPB-F200-49.pdf
Re: E body pedal assembly, I would like to convert to power brak [Re: ahy] #2375625
09/23/17 07:46 PM
09/23/17 07:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you want chevy, and ford parts on your car.
Re: E body pedal assembly, I would like to convert to power brak [Re: 71birdJ68] #2375672
09/23/17 09:01 PM
09/23/17 09:01 PM
IN
ahy Offline
ahy  Offline
IN
FWIW, the dual diaphragm booster pictured is basically a re-pop of the Hemi booster. Smaller diameter (8" dual vs 9" single) is handy for clearance and the "dual" part gives more boost which is nice for harder hi-po pads... also smaller piston area aftermarket calipers.
I run a similar booster with OE 1970 "E" PB linkage and it works well. If I did not have the linkage already, I might buy a kit as pictured.
Re: E body pedal assembly, I would like to convert to power brak [Re: formula S] #2375684
09/23/17 09:42 PM
09/23/17 09:42 PM
Washington/Las Vegas
1971 Gran Coupe Offline
